DrBoost
DrBoost Reader
12/12/08 11:45 a.m.
Can someone out there help me? I'm trying to help a buddy out and as of yet have not seen his van. It's a 2003 Windstar with the 3.8L. I'm feeding his descriptions to a guy I work with who worked on the Ford hotline for years. The ford guy says he needs an ignition control module because the "thick film resistor" is heating up. The Ford dealer I can actually get through on the phone has no idea what an ignition control module is (does HIS Ford have a magneto?) and a google search is coming up blank. Can anyone shed some light on this. He (the Ford hotline guy) says he's NOT talking about the coil, but I think the module is built into the coil housing????
stuart in mn
stuart in mn Dork
12/12/08 12:41 p.m.
A thick film resistor is most likely going to be mounted on a circuit board of some type, and is the sort of thing you're not going to be able to fix at home, so the whole circuit board/module/whatever it is will have to be replaced.
Hal
Hal HalfDork
12/13/08 12:56 p.m.
Not sure if the Windstar has a seperate ICM or if it is part of the Powertrain Control module (PCM) like on my 2001 Focus. But either way it is like stuart_in_mn says, that resistor is part of some control module which will have to be replaced.
Suggest you try another Ford dealer. Even if the Windstar does not have an ICM they should know that the ignition is controlled by the PCM.
Jensenman
Jensenman SuperDork
12/13/08 8:12 p.m.
They have you looking for the TFI (Thick Film Ignition) module which was used on the old EEC-IV systems which IIRC was phased out sometime in the mid to late '90's when OBDII became the order of the day. They were mounted on the side of the distributor for ages, then they were moved to the firewall on a heat sink and yes they would get hot and go tits up on a very regular basis.
That vehicle should have COP (Coil On Plug) ignition meaning it shouldn't have a TFI module.
EastCoastMojo
EastCoastMojo GRM+ Memberand HalfDork
12/13/08 8:31 p.m.
Could they possibly go tits down on occasion?
Strizzo
Strizzo Dork
12/14/08 4:16 p.m.
i thought the 3.8 had a coil pack ignition like the 4.2 from the trucks did? iirc, there was an ignition module that the coil pack sat on top of, which all sat on top of the intake manifold on the trucks, and i think on top of the valve cover in the fwd 3.8's
Jensenman
Jensenman SuperDork
12/14/08 8:37 p.m.
EastCoastMojo wrote: Could they possibly go tits down on occasion?
Only if they wanted to be on top.
AngryCorvair
AngryCorvair GRM+ Memberand Dork
12/14/08 9:48 p.m.
i like the way ECM thinks. Jensenman, you gotta get out more often. Sometimes you gotta try to make a puppy!
Jensenman
Jensenman SuperDork
12/15/08 6:45 a.m.
Um, how did I ever forget puppy makin'?
jI4gkM9KOJ6tyT2OB1i0lEBZhQN7SGz7xCoeCcaEO70OkiAHud4syyvrAMGYQFYB
