Datsun1500 wrote:
It really depend on how much $$ they want for the 2012. They do not drop much and it might only be a $2000 swing between 3 years old with miles, and a new one.
This is what we ran into when we were buying back in '09, there was a hiatus between '06 & '09 with no TDIs sold in the US, so everything used was at the newest an '06 and everything we were interested in was within a couple grand of what we could buy brand new for. So we bought new.
I've talked about it several times here, we have an '09, TDI (The "bad" CBEA one), DSG that we have owned it since new. Once the free 30K mile dealer service was finished, I have done all maintenance except for 2 recalls, 2 DSG services, new set of tires at ~43K, balance, and alignment myself. I do not own VCDS/Vag-Com, but do own a CAN-Bus capable scan tool.
As of this writing we are approaching 94K miles, relatively trouble free.
Since owning I have repaired or replaced:
- 1 Glow Plug/Cylinder Pressure Sensor at around 70K miles
- 1 Battery, just this past Saturday actually, left SWMBO stranded, over 5 year old OEM battery that has been completely drained at least once, expected maintenance.
- OEM Bridgestones were replaced north of 40K.
- Three low beam head light bulbs.
Another recent issue I haven't diagnosed/repaired yet is the left rear door will not open, from inside of out. SWMBO attempted to open the door while locked, the exterior handle pulled out, and didn't fully spring back into place. When there's space available in the garage again it will get further attention.
DSG service isn't that big of a deal, call around, get prices. If they'll let you provide your own fluids, filter, o-rings, and washer, it can be done for between $300-$400.
Our Jetta has had Mobil 1 ESP 5w-30 religiously every 10K miles, so far the DPF, and flapper valve are still functioning as they should. If the DPF fails (it's 1 piece on the CBEA) it will be replaced with a DPF delete kit and tune vs. a new DPF, shhhh, don't tell anyone.
While the HPFP failure obviously exists, it's unfortunate, but the internet has blown it out of proportion, knock on wood, we've hand no issues, and I have never hesitated to take our Jetta all over the country. I do regularly add 4 oz. of Stanadyne Diesel Performance Formula to the fuel tank when filling up though just for the added lubricity.
I go back and forth between a TDI Sportwagon and last generations A3 for my next car. I would not hesitate to own a TDI Sprotwagon.
