PHeller
PHeller PowerDork
12/15/15 10:36 a.m.
So we've got a few storms here in Flagstaff that have laid down a few inches of snow, which isn't a problem for my Tacoma, but that snow melts during the day, and I awaken to the road being a sheet of ice, for which my Tacoma is no match. I get to work, but I feel Scandinavian in my driving.
If we're doing any lengthy driving, usually we'll escape the ice and snow of Northern Arizona for warmer climates, and so we'll take the Fit (with snow tires) or we get the Tacoma a few miles outside of town for drier roads.
I'm afraid one of these times I'll be caught off guard in the Tacoma and need some traction. I don't want to purchase tires for the truck because I won't have it long.
What kind of tire chains or cable setups do you use?
KyAllroad
KyAllroad SuperDork
12/15/15 11:51 a.m.
Skip chains or cables and throw 700-800 lbs of sand in the bed of the truck. Instant traction in icy conditions.
Woody
Woody GRM+ Memberand MegaDork
12/15/15 12:00 p.m.
Most town highway departments allow residents to bring some sand home to manage driveway and sidewalk ice. Get yourself three or four Rubbermaid tubs. Each one will hold a very manageable 100 pounds of sand. They will also keep it dry. Drill a couple of holes through the handle area and use cable ties to keep the lids from flying off.
I like this better than any other solid form of ballast. In a collision, the plastic should break apart and the potential energy from the weight should dissipate quickly as the sand scatters. At least in theory.
In the spring, return the sand to the highway department's pile.
Woody
12/15/15 12:04 p.m.
The specs on my plow call for 400 pounds of ballast, so that's what I used. I even weighed them and they usually come in right around 100 pounds. You can even increase the effective load by moving them to the rear of the bed. I used this method for a bunch of years until I realized that I didn't really need ballast for traction.
Bonus: You have a handy supply of actual sand if you get stuck on glare ice.
java230
java230 Reader
12/15/15 12:05 p.m.
IMO these are the best bang for the buck. http://www.lacledechain.com/light-truck-and-suvs/alpine-sport-super-sport
Get chain, not cable. Get the "easy on" ones, laclede is the most common one I have found, being sold under lots of different 'tire store' brands. Get some extra rubber bungee cords that you can use to get them on really tight, it helps a ton with drivability.
foxtrapper
foxtrapper UltimaDork
12/15/15 2:10 p.m.
These seem like a heck of a good idea for the person who might need chains once or twice in their life.
https://zipgripgo.com/
iceracer
iceracer PowerDork
12/15/15 6:29 p.m.
I grew up when chains were the only alternative.
NEVER EVER AGAIN.
Nothing like a CJ5 with chains on all four.
Woody
12/15/15 7:32 p.m.
We put chains on the fire trucks when the snow is more than 6 inches deep. I really hate driving on them. They shake the truck apart and really slow us down.
pilotbraden
pilotbraden SuperDork
12/16/15 10:56 a.m.
Chains are great in the deep stuff, I can run 30 mph in snow up to the bumper. Plan on using a lot of fuel I get 2-3 mpg doing that.
edizzle89
edizzle89 HalfDork
12/16/15 11:56 a.m.
foxtrapper wrote: These seem like a heck of a good idea for the person who might need chains once or twice in their life. https://zipgripgo.com/
came here to say this, never used them but would be easy to throw in the vehicle and only use them when the snow gets really deep or your stuck.
PHeller
PHeller PowerDork
12/16/15 11:59 a.m.
I'm looking for something that I can run for a few days, to help with ice on the roads. The truck does fine in snow (4x4 helps) but its the ice that is the problem.
pilotbraden
12/16/15 1:40 p.m.
They grip on ice but they are rough and will wear quickly above 25 mph on hard surfaces.
bearmtnmartin
bearmtnmartin GRM+ Memberand Dork
12/16/15 2:33 p.m.
PHeller
PHeller PowerDork
12/16/15 3:20 p.m.
I dont want new tires because I won't be owning this truck in a year and chances of purchasing a vehicle with similar tires are slim.
Grtechguy
Grtechguy MegaDork
12/16/15 5:06 p.m.
This showed up on my facebook feed.
Basically zip strips with studs. Looks interesting for $25
Hal
Hal SuperDork
12/16/15 5:17 p.m.
PHeller wrote: I'm looking for something that I can run for a few days, to help with ice on the roads. The truck does fine in snow (4x4 helps) but its the ice that is the problem.
Chains are not for running continually. Anything over 20mph on a paved road will wear them out to the point of breaking. And when they break they can tear the E36 M3 out of brake lines, etc.
Your best bet is winter tires with a good ice traction rating.
logdog
logdog GRM+ Memberand SuperDork
12/16/15 6:15 p.m.
WildScotsRacing
WildScotsRacing Reader
12/16/15 6:48 p.m.
java230 wrote: IMO these are the best bang for the buck. http://www.lacledechain.com/light-truck-and-suvs/alpine-sport-super-sport Get chain, not cable. Get the "easy on" ones, laclede is the most common one I have found, being sold under lots of different 'tire store' brands. Get some extra rubber bungee cords that you can use to get them on really tight, it helps a ton with drivability.
Would you mind specifying your objections to the cable-style? It would seem to me they could better handle hitting the occassional patch of clear pavement better than chains.
Kenny_McCormic
Kenny_McCormic UltimaDork
12/16/15 6:55 p.m.
Chains are street legal in Arizona?
ihdYXfRABHkmy72q9KDHC09tksUOt8QTN4qlig2tiYNn6aNgSz5BLMUl4d4YC5Oc
