The needle valve is an awesome idea!
I made a half-hazard change to the code and I can get the valve to cycle (loop) while I hold the "enter" button, but lack the skills to change the code to cycle without the "enter" button. In testing I got accuracy within less than 1psi.
If someone was up to the challenge, it's the part between the red brackets that I'm trying to get to loop until input pressure = user set pressure
(I also have it on word format that is much more readable)
Good times.
The code:
* Version 3 code eliminates bugs with button presses and other inefficiencies in control of the device. The user will be instructed to attach the tire chuck
* and press the confirm button. The tire pressure and default set pressure will be displayed. The user will then press either
* the increase or decrease button until they have reached the desired pressure. The user will then press the confirm button to initiate the tire service process.
* Version 3.1 code makes some minor changes to text displayed throughout process. Also adds a flashing screen once the process is complete until the user
* presses the confirm button. One final change made to the range that the user can select for tire service. The range has been limited to between 0 and 60.
* There are two functions used for testing that simulate the device being hooked up to a compressor or pump. After the user
* confirms the pressure, the displayed sensor value will increment or decrement until it reaches the user set pressure value.
* Since a comparison of the values results in equivalance, the valve closes automatically.
* NOTE: In the compareValues() function, there are two lines of code with a function using tone(). These are built in functions for using a cheap little
* buzzer that came with the Arduino kit. If you are testing with the speaker circuit, then you will have to modify the code. I think that using the
* digitalWrite to the pin that is used for the speaker will work but I haven't actually tested that, yet.
* NOTE 2: If you are ready to test with a real speaker circuit and the valves connected. You should just have to change the tone() function calls to the digitalWrite
* as mentioned in "NOTE", uncomment all of the readSensor() and delete the inflateTire() and deflateTire() functions if using the sensor and/or valves.
char ESC = 0xFE; //variable given to hex number that must be used to initiate LCD commands that is used multiple times
const int increaseButton = 2; //variable to represent increase button given a value to represent pin 2 of the Arduino
const int decreaseButton = 3; //variable to represent decrease button given a value to represent pin 3 of the Arduino
const int confirmButton = 4; //variable to represent the confirmation/enter button given a value to represent pin 4 of the Arduino
const int increaseValve = 5; //variable to represent the increase solenoid valve given a value to represent pin 5 of the Arduino
const int decreaseValve = 6; //variable to represent the decrease solenoid valve given a value to represent pin 6 of the Arduino
const int buzzer = 13;
int increaseButtonState = LOW; //variable to represent the state of the increase button
int decreaseButtonState = LOW; //variable to represent the state of the decrease button
int confirmButtonState = LOW; //variable to represent the state of the confirm button
boolean increaseValveState = false; //default increment valve state with true meaning open and false meaning closed
boolean decreaseValveState = false; //default decrement valve state with true meaning open and false meaning closed
boolean processComplete = false; //variable when true means process complete
int sensorValue = 0; //this is a dummy value for testing
int setValue = 0; //initializes the setValue that will be displayed
void setup()
Serial.begin(9600); //Sets up communication with the PC for data trasnmission at 9600 baud
setupLCD(); //Function call to initialize the LCD for start up use of the device.
readSensor(); //Initially reads the sensor so that the default setValue can be set.
setValue = sensorValue;
* Sets three pins as inputs to observe a change in the signal on them.
* Sets two pins as outputs to send a signal dependent on the comparison of
* the actual tire pressure and the user set pressure.
pinMode(increaseButton, INPUT);
pinMode(decreaseButton, INPUT);
pinMode(confirmButton, INPUT);
pinMode(increaseValve, OUTPUT);
pinMode(decreaseValve, OUTPUT);
pinMode(buzzer, OUTPUT);
void (* resetFunc) (void) = 0;
void loop()
//This do..while waits for the user to select what pressure is required and press the confirm button.
do{
readSensor();
displayPressure();
readButtons();
while((confirmButtonState == LOW) && (increaseValveState == false) && (decreaseValveState == false));
//This do..while will display the values while comparing them to see whether inflation or deflation is needed.
do{
readSensor();
displayPressure();
readButtons();
compareValues();
while(processComplete != true);
//This do..while will call lcdFlash() repetitively until the user presses the confirm button
do{
lcdFlash();
readButtons();
}while(confirmButtonState == LOW);
delay(500);
resetFunc();
This function will turn the LCD display on and display a message for the user to attach the tire chuck
and press enter. This will allow the pressure to be read after the chuck is on the tire making both the
set value and actual pressure value the same, and still allowing for the user to change the set value
to the desired tire pressure for the operation.
void setupLCD()
//Turn on display and turn off blinking cursor
Serial.write(ESC);
Serial.write(0x41);
Serial.write(ESC);
Serial.write(0x4C);
//This loop will tell the user to connect the tire chuck and press enter and will wait to enter the main loop until
//the confirm/enter button is pressed or held.
do{
clearDisplay();
Serial.print("Connect to Tire");
cursorSet(0x42);
Serial.print("Press Enter");
readButtons();
* This function will display the pressure of the tire and the default set pressure for
* the user to visually compare to decide whether the tire needs to be inflated or deflated.
* Uses a call to a function created to keep the user set value that is displayed within the
* specified range in the arguments.
void displayPressure()
setValue = rangeConstraint(setValue, 0, 60);
clearDisplay();
Serial.print("Tire - PSI: ");
Serial.print(sensorValue);
cursorSet(0x40);
Serial.print("Set Pressure: ");
Serial.print(setValue);
* This function uses a variable for the tire pressure called "sensorValue"
* and sets it to receive the data on the analog pin A0 of the Arduino.
* The necessary conversions to display a correct pressure value are done and stored back
* into the variable.
int readSensor()
sensorValue = analogRead(A1);
float voltage = sensorValue*(5.0/1023.0);
sensorValue = (((voltage - 0.2)/(4.7 - 0.2))*100);
* This function will allow the buttons to be read. Pin 2 on the Arduino is connected to the button designated
* as the increase button and will increase the setValue displayed on the LCD with each button press. Pin 3 on
* the Arduino is connected to a button designated as the decrease button and will decrease the setValue displayed
* on the LCD with each button press Pin 4 is connected to a button designated as the confirm button.
void readButtons()
confirmButtonState = digitalRead(confirmButton);
increaseButtonState = digitalRead(increaseButton);
if((increaseButtonState == HIGH) && (increaseValveState == false))
setValue++;
decreaseButtonState = digitalRead(decreaseButton);
if((decreaseButtonState == HIGH) && (increaseValveState == false))
setValue--;
delay(250);
* This function compares the actual tire pressure value with the user set
* pressure value. If the values are different and depending on which one is
* larger, a signal will be sent to the SSR of the valve that needs to open.
* A boolean variable representing the valve state, true for open and false for
* closed, will change states. This will allow either valve to close again as soon
* as a comparison of the values results in equivalance.
void compareValues()
if((setValue > sensorValue) && (confirmButtonState == HIGH))
digitalWrite(increaseValve, HIGH);
increaseValveState = true;
else if((setValue < sensorValue) && (confirmButtonState == HIGH))
digitalWrite(decreaseValve, HIGH);
decreaseValveState = true;
delay(250);
digitalWrite(decreaseValve, LOW);
delay(250);
else if((setValue == sensorValue) && (increaseValveState == true))
digitalWrite(increaseValve, LOW);
tone(buzzer, 100, 2000);
processComplete = true;
else if((setValue == sensorValue) && (decreaseValveState == true))
* This function is used to keep the value that the user can set to between 0 and 60 psi.
* This is a limit set during design to avoid potentially damaging higher pressures.
int rangeConstraint(int value, int minimum, int maximum)
if(value < minimum)
return minimum;
else if(value > maximum)
return maximum;
* This function is designed to allow the LCD to flash. It will display a message and clear the screen.
* When this function is called in the main loop it is placed in a do..while until the user presses the
* the confirm button.
void lcdFlash()
clearDisplay();
Serial.print("Process Complete");
cursorSet(0x45);
Serial.print(" PSI");
delay(500);
clearDisplay();
delay(500);
* These functions are used only to eliminate code use. Contained within the functions
* are commands for controlling the LCD display. clearDisplay() contains the commands to
* clear the display and set the cursor to row 1, column 1. cursorSet(*) contains the
* commands to set the cursor anywhere within the two rows and 16 columns. The argument
* is used so that the programmer may set the hex value that chooses where to set the cursor
* to whatever is needed for that screen.
void clearDisplay()
Serial.write(ESC);
Serial.write(0x51);
void cursorSet(int hexValue)
Serial.write(ESC);
Serial.write(0x45);
Serial.write(hexValue);
