The poster formally known as 96DXCivic
The poster formally known as 96DXCivic SuperDork
11/15/10 12:58 p.m.
Where do y'all get torque wrenches and which style do you use? I have a HF click type and a Craftsmen bending beam one. Snap on and MAC Tools are out of my budget.
Toyman01
Toyman01 GRM+ Memberand SuperDork
11/15/10 1:19 p.m.
I use a Northern click type. Nothing has fallen off yet so it must do the job.
TJ
TJ SuperDork
11/15/10 1:50 p.m.
I only have HF ones. They are in my budget.
96DXCivic, why did you have to go and get so formal anyway?
WilberM3
WilberM3 Reader
11/15/10 1:56 p.m.
i really love my Precision Instruments split-beam type 3/8 wrench. i'd like their 1/2 too at some point. theyre not too much more than craftsman either if you find em online and a lot less than snapon.
1988RedT2
1988RedT2 HalfDork
11/15/10 2:24 p.m.
I sprang for a 3/8-drive Craftsman click-type a few, well okay, maybe 15 years ago. The 1/2-drive Craftsman click-type I got a few years later as a gift. Most of my stuff is Craftsman, but I'll confess to a set of Harbor Freight impact sockets.
I have a friend that bought a H-F torque wrench. He ended up stripping out some fastener or other because the wrench didn't click when it was supposed to. He later bought a different brand and tested them side by side and found that on low torque settings, the HF tool was off by like 100%. This was no beat-up old wrench either, the thing was brand new.
Giant Purple Snorklewacker
11/15/10 2:34 p.m.
If I hook my cheap HF up to my old man's snap-on they read identical. Bonus me.
joey48442
joey48442 SuperDork
11/15/10 2:36 p.m.
I have a proto brand click type my dad gave me. I love it. Used to have a craftsman click type. Both work great. I traded the craftsman for a Miata rollbar with a friend (which both I and my friend thought was a hardcore, it wasn't. Just ask paanta. (sorry again!)) and he is still using it. I recommend the craftsman for price, and it's a bit easier to set than the proto.
Joey
mndsm
mndsm Dork
11/15/10 2:39 p.m.
I have a 1/2 click type from Lowes- Kobalt. Lifetime warranty, seems to torque right up with pricier wrenches I've used. I do need to add a 3/8" to that pile, but for now, the 1/2" and a reducer do the trick.
paanta
paanta New Reader
11/15/10 2:41 p.m.
I've got an S-K click type one in 1/2" and a craftsman 3/8" clicky. The S-K is perfect. The craftsman is accurate, but absolute junk in every other way (numbers are all but unreadable after a couple years of use, hard to get it to hold its setting, etc). Both were purchased used on ebay. The 3/8" especially reaaaaaally needs to be accurate or you'll be stripping stuff left.
It's all good, Joey. I broke even on the whole thing, and got to know you better in the process!
spitfirebill
spitfirebill Dork
11/15/10 3:09 p.m.
I have Sears beam type that I used up till I bought a Sears clicker type from my uncle's estate sale. He had bought it quite a few years ago, so I hope its better that the current ones they sell. I will say I broke a brand new head stud with it reassembling my Spitfire engine. Not sure if that was a stud problem or a wrench problem.
digdug18
digdug18 HalfDork
11/15/10 3:19 p.m.
I have a kobalt one as well, if you check CL I'm sure you can find a snappy, mac, or matco one for nearly HF prices.
Andrew
StevenFV19
StevenFV19 Reader
11/15/10 5:31 p.m.
I don't like the Snap-On electronic ones, if you're in any environment that has any noise, its impossible to hear. I have a Craftsman click type as well as everyone else, it is awesome. Although I was torquing the center nut on my Dad's Formula Continental, 130lbs/ft, and the plastic handle snapped to pieces. It works fine for normal, un-herculean torque specs though.
Steven
triumph5
triumph5 HalfDork
11/15/10 5:39 p.m.
Craftsman 3/8" beam type and a Craftsman 1/2 click. one thing I've learned with the click type is always store them with the setting to zero ft/lbs.
I've assembled a few engines with the beam type with no problems, this winter will be the first engine built with the clicker.
turbojunker
turbojunker HalfDork
11/15/10 5:48 p.m.
I have to use the click type. For one, it's too noisy to hear the electronic beep, and it's hard to read a bar type when I'm straining like hell to put 600 ft/lbs on something.
Knurled
Knurled GRM+ Memberand HalfDork
11/15/10 5:57 p.m.
I was going to get one of the electronic ones, because they have a gyroscope that will measure your torque angle. Awesome! But $500 with a one year warranty. Not awesome.
Monster Toad
Monster Toad Reader
11/15/10 7:16 p.m.
I use a $10 Great Neck 1/2" beam wrench from AutoZone. I want a good clicky wrench.
Ian F
Ian F Dork
11/15/10 7:42 p.m.
I also have Craftsman wrenches in lo 3/8, med-3/4 and hi 1/2. Plus a 3/4" H-F. They have workede well enough for the tasks I've needed them for. I do think I'll spring for a new version in a year or two when I have to do the TB on the TDI again. Gearwrench sells a version that adds a torque-angle function which would make tighening the mounting bracket bolts a bit easier.
The most important thing about a torque wrench is to treat it like the delicate measuring tool that it is.
Ian F
Ian F Dork
11/15/10 7:50 p.m.
Knurled wrote: I was going to get one of the electronic ones, because they have a gyroscope that will measure your torque angle. Awesome! But $500 with a one year warranty. Not awesome.
http://www.thetoolwarehouse.net/p-9653-k-d-tools-85074.aspx
Less than $500, but still not cheap...
wlkelley3
wlkelley3 Dork
11/15/10 9:32 p.m.
Was using an old Craftsman beam style 1/2-drive. Recently won an Advance Torque Products 1/2 drive click-type in a drawing at a conference I attended.
Ranger50
Ranger50 Reader
11/16/10 8:51 a.m.
I have two beam ones from NAPA, 1/4" drive 0-60 in/lbs and a 3/8" drive 0-100 ft/lbs. I then also have an old Craftsman 1/2" drive 0-150 ft/lbs clicker plus a Husky 1/2" drive 0-250 ft/lbs clicker I bought in a store closing sale.
I don't like the click type or electronic wrenches as it is very easy to overtorque and you'll never know. Plus if you drop it, it is out of spec and who calibrates it afterwards? Nobody.
Brian
qUWDaREcVA60vmghMKuTNjyUtAV9Gvv9YbnAN7eZDD4ciSBh2Alp2lWY1RQCBCAF
