dyintorace
dyintorace GRM+ Memberand PowerDork
5/23/22 10:08 a.m.
We have a cheap wall clock that seems to have died. I've tried 3 different batteries with no luck. Is it possible to replace the assembly that runs it? This is the assembly on the back.
rob_lewis
rob_lewis GRM+ Memberand UberDork
5/23/22 10:16 a.m.
Check your local crafts type of stores (Michaels, Hobby Lobby, etc).  You should be able to find a similar clock movement there.  Usually under $20.  You'll have to carefully pull the hands off the old clock.  Check the shaft size to make sure it'll fit.
-Rob
Dirtydog (Forum Supporter)
Dirtydog (Forum Supporter) GRM+ Memberand Dork
5/23/22 10:18 a.m.
Well, it's right twice a day.  That's a start.
matthewmcl
matthewmcl Dork
5/23/22 10:22 a.m.
A clock kit will set you back about $10, and you won't have to take new stuff apart. If the kit comes with arms that are close enough, you don't have to save anything old but the face (pulling arms sometimes works, but not always). I did a quick AZ search and there are multiple options.
Slippery
Slippery GRM+ Memberand PowerDork
5/23/22 10:22 a.m.
5/23/22 11:01 a.m.
dyintorace
5/23/22 11:12 a.m.
Perfect. Thanks all!!
5/23/22 2:53 p.m.
These units are also available as plug ins if you wanted to convert.
5/23/22 3:44 p.m.
That's a way better average than I can manage.
CrustyRedXpress
CrustyRedXpress GRM+ Memberand HalfDork
5/23/22 6:41 p.m.
I'd double check the part numbers, but this appears to be the movement:
https://www.amazon.com/Youngtown-Movement-Mechanism-Replacement-Thickness/dp/B01LWN22B6
AOf2AJjcj59GYfCpNZYUPCwJd9piPz5qvjJAFhfp4GNv4BPuBmPuO2GEFfHPSCaf
