Adrian_Thompson
Adrian_Thompson MegaDork
8/6/18 9:34 a.m.
Pretty easy, but it just dawned on me over the weekend.
Image result for land rover series i 1948
Image result for original porsche logo
Image result for early cessna 172
Dusterbd13
Dusterbd13 MegaDork
8/6/18 9:46 a.m.
All have been around since ww2?
Hungary Bill
Hungary Bill GRM+ Memberand PowerDork
8/6/18 10:24 a.m.
Things Colton Harris used to get to the Bahamas?
Streetwiseguy UltimaDork
8/6/18 10:33 a.m.
All three are unreasonably and inexplicably popular?
Adrian_Thompson
8/6/18 11:39 a.m.
I'm surprised no one has got it although some are in the ballpark.  I thought I couldn't be the only geek to notice.
Adrian_Thompson
8/6/18 12:06 p.m.
Need an embarrassed emoji.  I relied on memory to post this, THEN I checked.  I thought they  were all introduced in 1958 hence 70 years old, but double checking the Cessna 172 was introduced in 1956, not 58 so just ignore my incoherent ramblings.
8/6/18 12:12 p.m.
They all originally had 4 cylinder engines?
stanger_missle
stanger_missle GRM+ Memberand SuperDork
8/6/18 12:36 p.m.
All will destroy you financially faster than a cocaine habit?
D2W
D2W HalfDork
8/6/18 12:41 p.m.
Technically don't they cause a cocaine habit thereby destroying you even faster.
SVreX
SVreX MegaDork
8/6/18 1:34 p.m.
Ok, more automotive based...
What do these 3 cars have in common?
(There are 2 correct answers. 1 is Challenge related, 1 is not)
MadScientistMatt
MadScientistMatt PowerDork
8/6/18 1:43 p.m.
Italdesign?
aircooled
aircooled MegaDork
8/6/18 1:45 p.m.
3 cars that have never been in my garage.
mtn
mtn MegaDork
8/6/18 1:46 p.m.
3 cars that their pictures are blocked from my works internet.
The0retical
The0retical UltraDork
8/6/18 1:48 p.m.
Well technically that's a Cessna 175 which was introduced in 1958.... So you're correct, I guess?
Adrian_Thompson
8/6/18 2:14 p.m.
In reply to The0retical :
Well that's strange.  I assume you googled the N number to get it was a 175.  The nose and cowl look more like a 172.  I thought the 175's all had the raised nose and cowl for the constant speed prop?  This is what I think of as the nose on a 175
The Skylark looks like a C-172 with the exception of the bump on top of the cowling for the higher prop shaft.
The0retical
8/6/18 2:27 p.m.
In reply to Adrian_Thompson :
Internet research from Googling the N number says the motor in N7688M was changed to a 6cyl HO 220HP a Franklin under an STC. He probably changed the cowl to the old 172 version and that's why it also has the single exhaust rather than the duals found on normal 175's.
I actually did lookup the N number because I was wondering what was up with the exhaust initially.
Mazdax605
Mazdax605 UberDork
8/6/18 5:14 p.m.
I'm sorry Cliff, but that is incorrect.
pilotbraden
pilotbraden UltraDork
8/6/18 5:32 p.m.
The hump on a 175 cowling is to clear the gearbox
Pete Gossett
8/6/18 5:50 p.m.
The obvious answer is 3 cars you’ve owned, but I also believe they’re 3 cars you sold to other GRMers, correct?
Trans_Maro
Trans_Maro PowerDork
8/6/18 5:57 p.m.
In reply to SVreX :
Soul sucking FWD?
SVreX
SVreX MegaDork
8/6/18 6:12 p.m.
In reply to Trans_Maro :
The SVX was (mostly) AWD
SVreX
SVreX MegaDork
8/6/18 6:14 p.m.
In reply to Pete Gossett :
Everything I own sells to GRMers, so that doesn’t  count.
Yes, I’ve owned them, but that’s not what I was thinking
Patrick
8/6/18 6:46 p.m.
You’ve challenged all of them?
Spoolpigeon
Spoolpigeon PowerDork
8/6/18 6:49 p.m.
Split side windows.
nutherjrfan
nutherjrfan SuperDork
8/6/18 7:40 p.m.
w/o looking or spell checking I'm gonna say Guigario.  Heck if Bertone can design the mkII Astra convertible.  smiley
5PLtsxdWKrPEUkAh2gdaI8ivTEc2hSyHNgbDLW4Hv4x1wEJgwr8KOg6nxAUwFMLC
