rustybugkiller
rustybugkiller Dork
7/19/24 6:00 p.m.
I have an old Makita hammer drill that the forward reverse switch stopped working. I tried RadioShack but all the toggle switches are either 2, 3 or six pole. I have 4 wires. It needs to fit inside the handle which will make it hard to purchase on line..Thanks
ShawnG
ShawnG MegaDork
7/19/24 6:37 p.m.
Makita supports their old stuff really well, have you tried using the model number and searching online?
rustybugkiller
rustybugkiller Dork
7/19/24 7:15 p.m.
Yes, but $36 plus shipping for a toggle switch
ShawnG
ShawnG MegaDork
7/19/24 7:24 p.m.
In reply to rustybugkiller :
But you can actually buy it.
What's a new Makita hammer drill worth?
Stampie
7/19/24 7:29 p.m.
You've probably tried but can the switch be cleaned/fixed?
DarkMonohue
DarkMonohue GRM+ Memberand SuperDork
7/19/24 10:09 p.m.
Exactly. A lot of switches can be disassembled, with a little persuasion, and the contacts cleaned up with some emery paper.
If replacement really is required, are there any markings on the switch that can help identify a new one? It's likely to be fairly configuration rather than a proprietary Makita design.
Oapfu
Oapfu GRM+ Memberand Reader
7/19/24 10:10 p.m.
I agree repairing/replacing/whatever with an OEM switch is the best option, but...
Get a "6 terminal" switch (which is presumably a DPDT = double pole, double throw) and "X" jumper across the outputs.  The original switch does the same thing internally.
Search for something like "how to wire a dpdt switch to reverse a motor" or "motor reversing switch"
rustybugkiller
rustybugkiller Dork
7/20/24 7:25 a.m.
In reply to Stampie :
Multiple cleanings didn't work.
rustybugkiller
rustybugkiller Dork
7/20/24 7:31 a.m.
I found a reverse polarity switch on Amazon with dimensions that are close. I need to check fit in the drill but this is another option since Radio shack has 6 pole switches I can put my hands on to check sizing. Thanks!
dculberson
dculberson MegaDork
7/20/24 8:05 a.m.
The most surprising thing I've seen today is that you have an open radio shack near you.
ShawnG
ShawnG MegaDork
7/20/24 9:35 a.m.
A DPDT reversing switch is for DC applications.
Your original switch will swap between two sets of windings in the field winding to handle reversing. It -may- be wired similar to that but it may not.
If you're using a non-OEM switch, get your meter out and figure out which wires go to which sets of windings and wire the switch accordingly.
Usually there's a part number on the original switch. Maybe google that and see if something cheaper is available from Mr. Bezos
Noddaz
Noddaz GRM+ Memberand PowerDork
7/20/24 9:55 a.m.
Also consider the time invested rigging a switch to work versus a switch that actually fits.  Just a thought.
DLSCLqUKFdFcmPwN2wNUu0DPYdzGDCaleA0EFouFUBXpZ3FJUG6mw2nscGv1F5sO
