Hi all
I'm in the process of resurrecting a utility trailer and putting in a rear axle assembly from a 2013 Grand Caravan. However, I want to swap the hub units to either 2000 Dakota 4x4 front hubs or d40 Nissan Frontier 2x4 front hubs so the BCD matches my yucktray.
The axle hole is a bit small for either hub but the Dakota hub is closer in size to the OD of the Caravan hub. How do I concentrically enlarge the hole in the axle to match the pilot sticky outy of the Dakota hub? Without much fussing around? Accurately?
I ASSume the hole must fit correctly to support the load safely, but that may not be the case.
Thanks in advance ![smiley smiley](https://grassrootsmotorsports.com/static/ckeditor/ckeditor/plugins/smiley/images/regular_smile.png)
How close is close?
I had to enlarge a set of rotors for a BBK and used one of those 3 stone honing tools you rent from a parts store. I don't know how thick that axle hole is though?
In reply to iansane
84.9mm (~3.34") to 88.9 (~3.5") so 4mm on the diameter or 2 (not quite .080") on the radius
thickness of the mounting plate is 9mm or not quite 3/8"
It looks like this
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2021/06/07/1623099294_95990391398040539bd95e1dbbe119c3_mmthumb.png)
Just a bump as I added some info above.
Also, I have a plasma cutter and die grinder and other means to add/remove metal. I'm looking for ways to be reasonably precise yet reasonably time efficient and cheap.
Cylinder hone lasted all of 5 minutes and didn't do much of anything. I have a couple ideas to try with what's left of the hone (peel and stick sandpaper) and I also think I can field strip one of the original hub units to use as a concentric guide to use a ridge reamer on it.
