NordicSaab
NordicSaab HalfDork
10/15/17 1:38 p.m.
Hey All,
It is time for me to move on to something new.  With that, I am selling or trading my 1993 Eagle Talon.  It has been proven to 660AWHP.  This car is an animal.  Some of you have probably seen it at the Mitty or other events. The car runs and drives and is tuned to run on e85.  This probably will be a car I miss.  Hopefully I can pass it on to an enthusist (and someone that wonln't kill themselves).
Link to pictures:
Pictures of 1993 Eagle Talon TSI
Modification List:
Stock 4g63 - Recently rebuilt with fresh bearings (<2000 miles)
Stock 4g63 Cylinder Head and Cams
Stock Transmission - Recently rebuilt (<2000 miles)
DSM Link v3 running speed density
GM IAT
GM MAP sensor
ARP Head Studs
Upgraded head gasket
Hawver Intake Manifold
ID2000 Injectors
8AN Lines to Tank
Walbro 455
JMF 8 Gal Fuel Cell
Modified stock fuel rail to 8 AN in and out
T3 Exhaust Manifold
Holset HX35w - recently rebuilt
1600 degree rated AN oil drain
3" Intake Piping
Large 3" in and out intercooler
3" Stainless Steel downpipe
3" Mild Steel straight Exhaust
BC Coil Overs (<1000 miles)
Oil Filter Relocation kit
Oil Cooler
Aluminum Radiator Tank
Aluminum Power Steering Tank
Unorthodox under drive pulleys
Mustang Cobra 17x10 wheels
275 Nitto NT-05 tires (<500 miles)
Welded in 6 point cage with strut brace
Flattened floor area
Gutted front doors
NGR Blow Off Valve
Jay's alternator relocation kit
Custom built radiator
x2 Spal 10" fans
Custom aluminum shroud
Tuned to run on e85
Dynoed and tuned at Tucker Performance in Palmetto, FL
660AWHP @ 42 lbs of boost
Car would pick up another 100+ HP with cams
Silicone Coolant pipes
AEM UEGO
Various Interior Gauges
Corbeau custom mounted seat on slider.
MOMO steering wheel
A/C Delete
Spec Stage 3 clutch
Spares:
6 Bolt Cylinder Head with Cams -
6 Bolt Cylinder Head w/o Cams -
Transfer case -
1 Cobra Big Brake Kit -
SFI Aluminum Flywheel -
Clutch and Pressure Plate -
If I were to keep the car I would make the following additional modifications:
Add doors with crank up windows
New TB with a IAC (Current TB has no IAC, as a result the car does not like cold starts, usually fine once warm)
I am offering the spares for sale separately as well.  I am flexible and open to trades of all types, up or down... complete cars, stock, modified, projects, etc.  Ask for everything is $X.  Will also sell the car without spares for $X.  Will provide a better price for someone I don't think will kill themselves.  I have yahoo so the messaging on here doesnt work very well for me.  For questions please text, call or e-mail (813) Area code 4802773, or JustinBragan@yahoo (dot) com.
Thanks for looking
Justin Bragan
Jaynen
Jaynen SuperDork
10/15/17 4:32 p.m.
Is it setup for drag racing or road racing?
NordicSaab
NordicSaab HalfDork
10/15/17 5:34 p.m.
In reply to Jaynen :
It was setup with the idea to be a multipurpose car.  I have used it for track, autocross, and drag at various events... each with a slightly different configuration.  In it's current form the turbo has too much lag for autocross. the suspension is fully adjustable depending upon your desire.
As a track car it works well, but does push at the limit. The fuel cell is 8 Gallons, so it needs to be refilled each session.
As a drag car I have not pushed the car very hard.  It pulls a consistent 1.6s 60' with a very soft launch using the launch control in DSM Link.  Just rowing through the gears will yield a 130mph trap.  To be honest, I don't have the guts to launch this car as it could be.
In summary, the car is a meh autocross car, an OK track car, and a great drag car.
Jaynen
Jaynen SuperDork
10/15/17 6:41 p.m.
Seems like the stock bottom end/transmission would have a hard time with 600whp?
NordicSaab
NordicSaab HalfDork
10/15/17 6:53 p.m.
The 6 bolt bottom ends are very robust.  At the end of the day it comes down to tuning.  The tune on there is very conservative (low timing), despite the 42 psi of boost pressure.  I am also running stock cams.  I've used this setup for several years and it just works.  I run more boost pressure, but overall, it is less stress on the engine.
The transmission is probably the weak link among everything.  I haven't done a 6K+ launch in a long time.  keep your launches smooth and it's a non issue.  Drive like a pissed off teenager and the transmission will break. A "built" transmission is about $1500 if you really want to beat on it.
NordicSaab
NordicSaab HalfDork
10/21/17 4:35 p.m.
Open to trades and offers.  I also have a 22' V Nose car trailer that is getting sold next!
NordicSaab
NordicSaab HalfDork
10/31/17 7:28 p.m.
Price drop to $X for car. Still open to trades.
Donebrokeit
Donebrokeit SuperDork
10/31/17 8:30 p.m.
Nice ride, GLWS.
NordicSaab
NordicSaab HalfDork
11/25/17 3:29 p.m.
Sale suspended (for now).  Mini build thread to be started shortly.
Go0do3QfsXBj16b7zCRFAp4D8KjM6mnBLSmmY1B0guLFgyGd1uudLL6541tMjiMZ
