jcs76
New Reader
8/16/22 11:09 a.m.
I put an air oil separator on my autocross car. It has two small diameter nipples which I understood were for a coolant source and coolant return.
When I started the engine coolant came out of the bottom drain hose when I opened the valve. What is this happening?
And what am I doing wrong?
Jon
Wait, wut?
Are you sure it's supposed to see coolant and not manifold vacuum?
iansane said:
Wait, wut?
Some separators are heated to prevent condensation from collecting in them and contaminating the oil.
JSC76 what separator are you using?
As in, ones that drain back to the crankcase? I guess that makes a little sense.
I've only ever dealt with ones that their entire point was to get things to condense, and then drain separately.
jcs76
New Reader
8/16/22 5:28 p.m.
In reply to APEowner :
I used a PQY Performance unit.
Those aren't necessarily know for quality. My first guess is that the unit is defective.
This one? https://www.alibaba.com/product-detail/Universal-Air-Oil-Separator-Catch-Can_62336011511.html
Looks like a Radium knockoff. They even left Radium's logo in the installation diagram...oops. If the coolant ports are hooked up correctly, maybe it's leaking coolant internally.
jcs76
New Reader
8/16/22 7:35 p.m.
In reply to obsolete :
yes, that looks like the one I have......
