AX2007
AX2007 None
8/6/23 12:07 p.m.
Hi all,
I currently have a 2005 Ford Focus track build that I have been enjoying in the garage as much as on track. I just finished swapping in a 2.5 Duratec, and learned that I can move the alternator to the front using a Mazda 5 alternator instead of the stock one. The main issue is that the Mazda 5 alternator is 3 pin, and the original alternator is 2 pin, along with the plug. Is it possible to switch out the connectors? Do I just cut the two pin harness and solder in a 3 pin? Any help is appreciated.
Thank you!
jfryjfry
jfryjfry SuperDork
8/11/23 10:02 a.m.
Try posting in the grassroots Motorsports thread or in the build Section - probably have more luck!   Wish I knew
iansane
iansane GRM+ Memberand Dork
8/11/23 10:38 a.m.
Looks like a charge wire and the two secondary wires go directly to the pcm. Don't know their specific function though.
juVQ3OGlWRj7JXPXlWV1878EC9utITvJcPtoLIiFGFsSQSrRhxFsJTBP8eaxyJlX
