ClearWaterMS
ClearWaterMS New Reader
3/10/22 1:18 p.m.
what does everybody use to pump ATF/gear oil/etc. into their cars?  I currently use the little bottle pumps that you stick into the bottle with the little hose that inevitably falls out of the fill hole and makes a mess.  I am looking for a better option that is preferably easier than holding the bottle up in the air and pumping that little thing on top 1 Tbsp at a time for multiple quarts...
what does everybody use?
preach (dudeist priest)
preach (dudeist priest) GRM+ Memberand Dork
3/10/22 1:36 p.m.
Drill pump and tygon tubing.
ClearWaterMS
3/10/22 2:33 p.m.
thanks, do you get a pump that is fuel rated?  What diameter tubing?  The fluid that I replace is typical D4 ATF and 75w90.
3/10/22 6:33 p.m.
Usually use 1/4" tygon, get braided if you are pumping heated fluids. I'd definately check to make sure your fluids will not melt the pump internals.
amg_rx7 (Forum Supporter)
amg_rx7 (Forum Supporter) SuperDork
3/10/22 10:24 p.m.
What exactly is a drill pump?
Oapfu
Oapfu GRM+ Memberand New Reader
3/10/22 10:41 p.m.
In reply to amg_rx7 (Forum Supporter) :
A small rotary pump of some kind, intended to be powered by a hand drill.
The specific one in this YT vid looked kinda slow: https://youtu.be/ozeE8_C8HLw?t=1750
3/21/22 9:15 p.m.
I like the hand pumps that thread into a gallon jug.
I weigh roughly 210-220lb. Pumping 85W140 in a 40 degree garage will have me lifting my body off the ground as I lay under the car.  My hands hurt just thinking about trying to squeeze three bottles in under those conditions!
RossD
RossD MegaDork
3/21/22 10:58 p.m.
Turkey baster. I keep one for garage use.
Z84h0vEhQpHiw29B2qRLYg7A8Hebqyy0KUfkNpbGie6IBSwDmx11h94ImX5nFtlP
