250cc 2-smoke should start with this correct?
150psi came on 3rd (40, 100, 150 approx when kicking)
So true. I had an 80's Husky once that was hell to start, and it turned out it was a total piece of cra- uh, I mean, the ignition timing was way, way off.
I've bought a ton of 2 stroke that guys said "it ran great the last ride i was flying then it would not restart the next day" sheared the flywheel key when they hamered a big jump or log etc. $2.00 fix.
44
If it has reed valves check for a bad one. It will still have compression with a bad reed, but you won't get a good air/fuel charge to the combustion chamber. IDK if a '78 yamie IT is reed or piston port induction, but reeds were showing up on a lot of Jap MX bikes by that time.
