This has been a long road with a lot of bumps along the way but I "think" my 1998 Buell Cyclone is almost ready to come to life again. I am trying to set the camshaft timing and would like some input as this is my first time taking apart this kind of engine. Take a look, good, bad?
This is what the "book" say the cam timing should look like.
This is what I have.
Yes I will have a build thread.
Thanks Paul B
Looks right to me. Matches what is in my FSM for a '87 883/1100.
looks right to me as well......
hope we aren't all wrong? What happens if you rotate it through 2 revolutions... does it still all line up??
Knowing Harley, they would pull a Chrysler 2.7 deal. Rotate it around and nothing lines up again for another 300 revolutions....
Nice when I fixed the king rat punky buellster the repair manual didn't explicitly say how to time the cams just showed a picture something like you showed minus a few cams. I had to go an ask Harley service. The B last manual has a few incontinences. The repair manual also shows the main breaker wired incorrectly from where the stator goes into the breaker. If you wire it incorrectly the bike will run fine but the harness is unprotected if the battery terminal comes loose. Oh I love my buell. Good luck with it!
The main reason I asked for input is the service manual did not state where the front or rear piston should be when setting the timing. I thought I had the timing correct I just wanted some input, thanks.
Ranger / oldeskewltoy: I spun the engine over and the marks line up without issue (unlike GM and Chry)
Benzbzron: Have you looked on Bad weather? They have some service and owners manuals you can down load.
Thanks for all the input I plan to install the right side cover tomorrow and try to fire the bike off
Paul B
Well good news the bike started up today and sounds ok I plan to take care of some odds and ends tomorrow and go for a ride.
Thanks everyone.
Paul B
