AutoXR
AutoXR HalfDork
4/9/12 9:02 p.m.
Getting my 80 GS450 ready for the road.
  • New Pirelli Road Demons
  • EBC -pads 50 tooth rear , 14 tooth front...
and that's where I hit a problem - Stock chain isn't fitting and there seems to be almost too many choices.
Suggestions?
Dr. Hess
Dr. Hess UltimaDork
4/9/12 9:05 p.m.
Cheap and useable or expensive and long lasting? Although I would bet that a GS450 doesn't put as much strain on a chain as a Harley dresser.
AutoXR
AutoXR HalfDork
4/9/12 9:10 p.m.
In reply to Dr. Hess:
I can get the parts through work @ cost so I would rather step up and not have to do this over and over!
foxtrapper
foxtrapper UberDork
4/10/12 4:58 a.m.
Is the stock chain not fitting because you've so altered the sprocket ratios it's too long/short? Or is it because of weird modifications or such.
Chain replacements are easy, normally, so it's not a big job. A GS450 doesn't stress a chain much at all, so even a cheap chen-shing type will hold up for years, with proper maintenance.
4/10/12 5:24 a.m.
I like the oilless O-Ring jobs. A little more pricey, but you do it less often.
Dan
Curmudgeon
Curmudgeon MegaDork
4/10/12 7:30 a.m.
I'm with Dan. Gimme an O ring chain any day, less mess etc. When riding enduros I always used them along with Sunstar steel sprockets, the combo lasted a long time compared to the guys running aluminum sprockets and non Oring chains.
You say you can get stuff through work; that's good. For those who can't D2Moto has O ring chains for ~$60.00. No affiliation, etc.
Dr. Hess
Dr. Hess UltimaDork
4/10/12 8:19 a.m.
If you have the money for it, then an O-ring chain is the way to go. My friend put one on his Harley in Anchorage, AK, rode home to Texas and adjusted the chain once.
AutoXR
AutoXR HalfDork
4/10/12 11:31 a.m.
I put a 50 tooth rear sprocket on it - so I need a longer chain. I want to go O-Ring, but the 510 - 520 - 530 ratings confuse the hell out of me
rotard
rotard HalfDork
4/10/12 11:47 a.m.
Well, what kind of sprocket did you put on it? Is the sprocket a 510, 520, 525, etc. sprocket?
AutoXR
AutoXR HalfDork
4/10/12 12:24 p.m.
just looked it up,makes sense now..
530-110
what do the # designations mean ?
44Dwarf
44Dwarf Dork
4/10/12 12:27 p.m.
Chain Size Chart Chain Size Pitch Inner Width - roller
415 1/2 3/16
420 1/2 1/4
520 5/8 1/4
525 5/8 5/16
530 5/8 3/8
630 3/4 3/8
drmike
drmike Reader
4/11/12 7:49 a.m.
530-110: the 110 means 110 links in the chain. My CB900F has a 530-114, for example.
BTW, if you do go for an o-ring chain, D.I.D. is a good brand to go with.D.I.D 530VM X-ring chains have a good reputation.
Curmudgeon
Curmudgeon MegaDork
4/11/12 8:15 a.m.
DID, Tsubaki and RK have all been good for me.
AutoXR
AutoXR HalfDork
4/11/12 8:38 a.m.
Ordered a D.I.D O-ring chain $44 dealer cost!
Thanks guys!
yTunlp3rSzMrZcmswlTLKs8MdsqealPQf8ayX7TQ3gvKbWsmBUTxkKIeZRMv3iIq
