cabbagecop
cabbagecop New Reader
10/31/16 5:47 a.m.
I know Harleys don't get much love here but seeing if I could get some help diagnosing an issue.
I recently changed out the lifters in my 96 Fatboy due to one of them failing. I also changed to an S&S breather. I have put about 200 miles on it since then. Today while riding it suddenly lost power and died.
Symptoms: Sudden power loss and dieing Sounds like it is backfiring out of carb Spewing oil out of air cleaner breather Can restart but will not stay running.
Any ideas?
Huckleberry
Huckleberry MegaDork
10/31/16 6:55 a.m.
Timing moved?
bentwrench
bentwrench Dork
10/31/16 7:08 a.m.
Adjustable pushrods? One came loose?
cabbagecop
10/31/16 7:31 a.m.
Yes it has adjustable pushrods I had just adjusted them but will check them again.
The cam position sensor plate hasn't moved so ignition timing shouldn't have moved. It's an Evo so the cam is gear driven not sure how it could move timing without a major failure. I will be pulling the nose cone to check it though.
cabbagecop
10/31/16 5:06 p.m.
Bentwrench you called it. The front exhaust pushrod had shortened itself about 2 inches.
44Dwarf
44Dwarf UltraDork
10/31/16 7:37 p.m.
well guess i'm an hour and a half late... Did it bend or did the adjuster just screw in? blue lock tight on jam nuts or if you can find it purple self wicking.
cabbagecop
10/31/16 8:00 p.m.
I believe it just screwed in. Didn't appear to be bent I so adjusted it back out and the bike fired off with out any issues. I checked to make sure they were all tight. Next day off I will go through and readjust and Loctite all 4.
44Dwarf
44Dwarf UltraDork
11/1/16 4:29 p.m.
Just don't use red and you'll be good.
BrokenYugo
BrokenYugo UltimaDork
11/1/16 6:36 p.m.
This sound like a job for a nyloc nut.
Dr. Hess
Dr. Hess MegaDork
11/1/16 7:50 p.m.
Harley's get lots of lovin' here. Bunch of us with them.
Glad you found the issue. Also, make sure you have a little loctite on the lifter block screws. They can come loose on you.
This site: http://www.hdforums.com/forum/evo-classic-models-84/
is where you wanna hang out for all things Evo.
cabbagecop
11/1/16 7:55 p.m.
Yeah the lifter blocks got blue Loctite when I put them on. Didn't do the pushrods but will now.
THlFF9NPDKMSHpQb863lmFIz2mc2xNNCPIdbirn9VAMeRP7pGSn0Zr1saNESfiZw
