octavious
octavious HalfDork
12/18/15 6:44 p.m.
Title says it all. Right side of a 2003 Ducati Monster 620. Battery tender?
Brokeback
Brokeback Reader
12/18/15 6:48 p.m.
Looks like one to me; I've got a Battery Tender brand and mine are slightly different than that. So look at brands other than that :-)
foxtrapper
foxtrapper UltimaDork
12/18/15 8:37 p.m.
No. Does not look like mine. Especially with that water tight seal.
Woody
Woody GRM+ Memberand MegaDork
12/18/15 9:41 p.m.
It might be for a Ducati brand charger.
Trans_Maro
Trans_Maro PowerDork
12/19/15 12:49 a.m.
Yes, looks the same as the one on my 'Guzzi Stelvio.
Mine usually has a "battery tender" brand USB adapter stuffed into it but at the moment, my C-tek battery maintainer is plugged into it.
If in doubt, stick a meter in it.
44Dwarf
44Dwarf UltraDork
12/19/15 9:50 a.m.
It does look like a good one to me. Bet you have a powerlet socket on the left side too.
minimac
minimac SuperDork
12/20/15 12:36 a.m.
It's the same as the battery tender plug I have on my Burgman, but why not just follow the wire? It's not like there's a ton of body panels to remove to see.
WOW Really Paul?
WOW Really Paul? MegaDork
12/23/15 12:33 p.m.
It is for a tender, As it is used, Id still check where it goes just to be sure.
foxtrapper
12/24/15 9:13 a.m.
Every battery tender plug I've seen looks like this:
They aren't equipped with a water-tight seal like the op's picture. The battery tender plug also wouldn't fit into the op's plug.
That picture looks like a watertight accessory plug to me. It might also fit up to a proprietary charger plug.
Not saying it couldn't be used for charging, or even used with some modification with a Battery Tender (R). But I really don't think it's a battery tender/charger plug.
EvanB
EvanB GRM+ Memberand UltimaDork
12/24/15 10:26 a.m.
In reply to foxtrapper:
The battery tender plug will fit in the socket pictured in the OP. It does have the weatherproof shield but is the same plug design.
kq6iiMCJzSg8lvVBCqjTXUSMFqDHFjS8fw1saC51MrZlwhHT4PjaIANXLjsnOOwy
