96DXCivic
96DXCivic Dork
3/29/10 2:26 p.m.
Can some explain how wheel bearings are done in this setup?
nocones
nocones GRM+ Memberand Reader
3/29/10 2:28 p.m.
It's basically the same as a FWD wheel bearing. The wheel is held on a live spindle that is pressed onto either a double row angular contact bearing or a combination tapered bearing.
Giant Purple Snorklewacker
3/29/10 2:29 p.m.
The VFR-750 Was the greatest motorcycle ever made. It had an aluminum single-side swing arm.
/thread
Tom Heath
Tom Heath Marketing / Club Coordinator
3/29/10 2:30 p.m.
Giant Purple Snorklewacker wrote: The NT-650 Hawk GT was the greatest motorcycle ever made. It had an aluminum single-side swing arm. /thread
Fixed that for you...
3/29/10 2:33 p.m.
Tom Heath wrote:
Giant Purple Snorklewacker wrote: The NT-650 Hawk GT could have been the greatest motorcycle ever made (like the VFR is) if it had a liquidy smooth and torquey V4. It did have an aluminum single-side swing arm though making it a nice option if you are not blessed with the good sense to own a VFR. /thread
Just a slight correction
kcmoken
kcmoken New Reader
3/29/10 2:40 p.m.
Tom Heath wrote:
Giant Purple Snorklewacker wrote: The Ducati 916 (and variants) were the greatest motorcycles ever made. The NT-650 Hawk GT and VFR750 are runner-up. Actually the RC30 ranks above both. These are nice options if you are not blessed with the good sense to own Italian. /thread
Come on now, the Ducati is clearly superior to the Honda...
kcmoken
kcmoken New Reader
3/29/10 3:10 p.m.
I thought about the GTS1000 as well. I wanted to verify before I put that up; I thought it had single sided swingarms front and rear. But alas, front only. I had opportunity to ride one and almost bought it. Probably should have as that opportunity is not likely to present itself again.
snipes
snipes Reader
3/29/10 3:18 p.m.
ok then, so how do spoke wheels and single sided swing arms work?
nocones
3/29/10 4:15 p.m.
The same way spoke wheels and a British car work. They have a splines on the live hub that a splined spoked hub interfaces with. This way the spoke center section comes off but can still take drive torque. Alternately they can use a drive plate with a non-splined hub and use drive studs or rubber blocks to drive the wheel.
Jamesc2123
Jamesc2123 Reader
4/2/10 1:12 a.m.
racinginc215 wrote:
Tom Heath wrote:
Giant Purple Snorklewacker wrote: I
am
so
confused
hotlink?
4/2/10 1:18 a.m.
Jamesc2123 wrote:
racinginc215 wrote:
am
so
confused
hotlink?
Purchase a 95 or so VFR and all will be clear. Some people find jesus... they should have kept looking.
Taiden
Taiden Reader
4/3/10 4:52 p.m.
Excuse me, VFR 400?
/thread
motomoron
motomoron Reader
4/6/10 3:08 p.m.
I'll see your 916/955/996/998 variants, NT650s and VFR 750s and 800s and raise you the actual single sided swing arm winnah, hotlinked here for your motorcycle fapping pleasure.
The 1990 Honda RC30 - though it carried the "VFR750R" designation I'll assume that previous posters would have said "RC30"...
kcmoken
kcmoken New Reader
4/6/10 4:08 p.m.
I had the RC30 on there already. NO hotlinked picture though.
I'll take the Ducati over the RC30 every day though. Granted if I am buying today I can't afford the RC30. The RC30 makes less than 100 hp.
snipes
snipes Reader
4/6/10 4:34 p.m.
nocones wrote: The same way spoke wheels and a British car work. They have a splines on the live hub that a splined spoked hub interfaces with. This way the spoke center section comes off but can still take drive torque. Alternately they can use a drive plate with a non-splined hub and use drive studs or rubber blocks to drive the wheel.
Ok but I was still missing how the disk brake worked out with the dish of the wheel. So I went and looked.
The wheel is not built like a bicycle wheel at all . It seem to help that the rear rim is so wide. The spokes do not meet at the center of the rim. They run from one side of the hub to the opposite side of the rim. Also they kept the rear disk diameter small and mounted the piston on the out side(like most bikes). It's cool to see when good engineering gets all 10lbs of E36 M3 in a 5lbs bag.
eXHyczJsTTW2sI13EZVe4rRU5Ts2SP2irpFb7Kw8UY4hw98tgejDg4r8pHjlXRca
