silentnoise713
silentnoise713 New Reader
7/1/15 11:59 p.m.
The difference it not that great but my spring perch is not very ‘wide’ and it looks like only half of the spring actually sit on it. Is this safe? IF I can use these, would I need to use o-rings or ‘something’ to align them??
armt350
armt350 New Reader
8/1/15 4:43 a.m.
Those fit like my KW supplied springs and perches on the rear side of my Z. they have been handling track abuse just fine.
chiodos
chiodos HalfDork
8/1/15 5:28 p.m.
If 1.5mm is enough for you to worry about then have someone turn it down. Otherwise I wouldnt worry.
SVreX
SVreX MegaDork
8/1/15 5:45 p.m.
Wrap the strut with tape before mounting the spring to center the spring.
You are not going to break the perch. If you do, you have a very different problem (like very poorly constructed perches).
84FSP
84FSP HalfDork
11/1/15 8:32 a.m.
I'd run them.
auX2bx5582r26tckTs1r7CBoxRpQEA3Fp42VuFqeIbzJFZbf2ljHnDGH9RlrhFS3
