Potential challenge car.
Ive bought a 1999 grand prix with a built motor and speed parts but bad trailing arm mounts.
I just went and looked at a 1997 grand am circle car with a full cage and a bad trans. Comes with a quad4 motor, needs some rust repair in the floor and the rockers are gone but the trailing arm mounts look solid.
If i read everything right i can drop the cradle and swap the motor and trans/struts ect all in one go?
Are the quad4 and 3800 harness and ECM anything close to each other? I can of course pull the whole harness from the grand prix,
But it sure would be easier if the harness and PCM were compatible with a few changes?
Also... This car has a cage that goes all the way to a loop that runs through tbe fender and up all the way around the radiator saddle and back all the way to the bumpers. Do you think i could just run a couple new bars down to the trailing arm mounts?
Any help appreciated!
