DaveEstey
DaveEstey UberDork
1/14/14 11:28 a.m.
Print out small label using label printer or just your PC printer. Place along wire. Seal with clear shrink tube. Done. Much cleaner than flag labels.
Don't be afraid to label in a common sense manner too. "To battery" "From battery"
Swank Force One
Swank Force One MegaDork
1/14/14 12:00 p.m.
That probably holds up a little better than my method. I hand write them on white shrink wrap close to the terminated end (plug, whatever), then shrink down. Nice for patch harnesses, probably not as nice for engine harnesses.
Good tip! Will keep it in mind.
Nashco
Nashco UberDork
1/15/14 12:10 a.m.
Works even better if you use the heat shrink with clear adhesive lining. Still not 100% protected from the elements but pretty close. I'd like to figure out a printer+paper combo that is water proof and try that next. The tiny label printers are too cumbersome and any exposure to chemical cleaners vaporizes the letters.
Bryce
DaveEstey
DaveEstey UltraDork
1/15/14 8:59 a.m.
Avery makes some pretty resilient coated papers
dweuL4ap6g2NXjjqqULLxlK6HpfTkGDfyJPkEmLHQ0I14Mk7v5shx2NXzuaYgnih
