escort1991
escort1991 New Reader
8/18/15 10:18 p.m.
I've been looking to do a retrofit of projectors on my Speed Triple. Looking at the normal Bi-Xenon, I started leaning towards LED projectors. Now, I catch figure out how they exactly work. I get the just of reflectors in usual headlights.
First: Do the LEDs use reflectors or just use the projector lense to magnify the beam?
Second: how do Bi-LEDs work? Are they like BiXenons with a cut off? Or do the use a second LED? Or neither?
Teach me....
Thanks
Grtechguy
Grtechguy UltimaDork
8/20/15 10:36 a.m.
No input, but I'm curious as well..
lastsnare
lastsnare Reader
8/20/15 11:19 a.m.
it looks like the Retrofit Source is selling some very reasonably priced kits (at least for the non-bi LEDs ... Corolla and Murano).
what I gather so far about them:
I don't know too much about the bi-LEDs either (2nd LED vs solenoid actuated cutoff shield that flips down), but curious to see what anyone has to say who may have tried them already.
I guess they can get hot, so some airflow is probably important over the heatsink,
that might be a consideration when deciding where and how to mount them on a vehicle.
They seem to use a similar configuration as xenons, i.e. a lens to focus the beam pattern.
Up until now I had never considered them because of availability and price.
But it looks like some of them are now in a similar price range as xenon retrofits, which I might try within the next few months myself.
escort1991
8/20/15 11:25 p.m.
Looks like the are a dual LED for high beam, no cutoff solenoid like bi-xenon according to this thread:
http://www.hidplanet.com/forums/showthread.php?53004-Dual-beam-LED-projector-Lincoln-MKZ
Now, as far as the airflow over heat sink. I'm not too worried for my application. If I can't get enough airflow over the heat sink while on the front of the motorcycle, I need to selling anything with wheels. But yes, it is a common issue.
Ultimately, I want to find/design a bi-LED system with 2 projectors.
escort1991
10/26/15 11:13 p.m.
Anyone else have any input of the pros/cons between HIDs and LEDs as far as headlights go?
Also, does anyone have any connections?
Grtechguy
10/30/15 2:39 p.m.
Bumping this, the only "con" I've heard with HIDs, is the UV output will discolor plastic lenses over time.
uQIZ0GlHIHARxoQMxu9dwPOyVSdWHSRpLaOeQajCyxvQ9JShunpO0JhFXQgXCyQz
