kylini
Reader
2/21/15 5:51 p.m.
I'm smart. Real smart. I took the valve cover off my 1999 Miata and, thinking I might as well paint it this time, I decided to twist off the metal nipple with vice grips.
So... apparently this isn't a replaceable part. I just crushed mine to oblivion so I can't exactly JB Weld it back on. Supposedly, the original is pressed into the valve cover.
1) Where on earth do I buy a new valve cover vent nipple? This is the metal tube sticking out of the driver side, which normally spits into a hose that recycles into the intake before the throttle body.
2) If by some miracle I buy one, how do I install it into my valve cover?
3) If I'm totally screwed, anyone got a non-VVT valve cover for cheap?!
How big is the hole? Hose size? You can probably get a barb from the hardware store/home depot that you can epoxy in or tap the hole for.
Tap it, insert barbed fitting.
Figure out what size it is and check Grainger or McMaster Carr.
kylini
Reader
2/21/15 7:19 p.m.
I like this line of thinking. I'm currently stuck on the last baffle screw (I reassembled it pretty tightly last time...). I'll bring it to a hardware store tomorrow and get something that'll fit.
kylini
HalfDork
2/22/15 2:57 p.m.
Great success! Yes, I tapped the hole in the middle of an Ace Hardware. I'll use JB Weld to reinforce the new barbed fitting because 1/8th threads are only barely larger than the original hole.
