lownslow
lownslow GRM+ Memberand Reader
5/21/24 10:06 p.m.
Thanks. Those are similar to what I was looking at.
AAZCD-Jon (Forum Supporter)
AAZCD-Jon (Forum Supporter) UltraDork
5/22/24 12:38 p.m.
+1 for the Forceum MT 08 in 13". I get a slight rub on the front right going over bumps with stock suspension, but generally a good fit.
dannyp84
dannyp84 HalfDork
5/22/24 2:23 p.m.
Has anyone calculated their real world mpg on these? I wonder if one would make sense for my 3 mile drive to work.
dan0
dan0 Dork
5/22/24 4:00 p.m.
I have not calculated mileage yet. I don't drive it a ton. I've heard other people comment numbers 30-50mpg. I think a lot depends on the vehicles condition maintenance wise and speed driven. You said 3 mile commute so likely you'd be getting on the higher side of that.
lownslow
5/22/24 11:27 p.m.
Did you upgrade your springs? That is first on my list.
5/22/24 11:59 p.m.
+1 for the Forceum MT 08 in 13". I get a slight rub on the front right going over bumps with stock suspension, ...
Not upgraded yet, but I plan to after ...other project cars. For now, having some weight in the back to balance it is enough to keep it from rubbing in the front.
lownslow
5/23/24 1:08 p.m.
I'm not going to lift mine, but a stiffer spring in front will hopefully help.
dan0
dan0 Dork
6/2/24 3:01 p.m.
Makes a good mobile work bench.
LSXS2K
LSXS2K New Reader
7/3/24 5:53 p.m.
In reply to AAZCD-Jon (Forum Supporter) :
Do you mind sharing the type of wheel this is?  I'm trying to find some Civic VX wheels but having no luck and I like the look of these.
z2V4sUFF3svVWnhIPyQmMn1XmN9IprZp6YALR0wOvV9tZ2NSvpdEKxM4fLCuJ4mX
