Long story, but to cut to the chase. This is going to be a really boring build thread, no hi-po or mad tricks at all. Just hoping to come out of it with a reliable tow vehicle on a budget.
Photos and story below if I can figure out how to post photos, so you can see all the madness. The place I could use your advice is on checkout and refreshing the donor engine.
The truck is a 2015 Ram 2500 6.4 hemi, automatic, 145k miles, rod knock.
The donor is a 2104 Ram 2500 6.4 hemi, badly wrecked. 69k miles on the clock when it stopped.
So my wonderful helper and I cut the engine out of the wreck. The oil pan was cut by the crossmember in the wreck but the crank turns OK. The motor mount bolts broke off in the block but the block is OK. Some ears on the front cover are broken but I can swap that from my truck. So far the engine looks OK. My main question now is how far to dig into it, what should I check or replace or leave alone? Your advice is welcome. My thoughts so far are:
Replace:
spark plugs, water pump, belt tensioners, what else?
I need to swap the oil pan anyway, so I can take a look at the bottom end, would you open up and look at rod and main bearings or just leave them alone?
I need to swap the front cover, so I can look at the timing chain etc while I am there. Leave it alone or refresh? Oil pump?
There is zero evidence of rear main seal leaking so I am inclined to leave the flex plate and seal alone. Or or would you change it?
Valve covers don't look like they are leaking, any reason to open them up?
Any particular common failure items I should replace while the engine is out?
Planning to use transmission, transfer case, intake manifold, wiring harness and sensors etc, all from my truck not the wreck.
This is a balanced budget kind of project. I can afford to replace things that will be likely to make this a more reliable long term tow vehicle. But I don't want to just replace everything in sight whether it needs it or not, nor do I want to open any cans of worms that I don't need to.
Here is today's trophy shot:
Here is the Copart photo that convinced me to buy a truck that turned out to have a rod knock. Looks good doesn't it? $6500 for for a 2015 Ram 2500, such a deal... I knew it would need work, I rolled the dice, I got an engine swap.
Then I found out how expensive Hemi's are, and especially the 6.4. So I doubled down and bought a wreck from Copart. This one was relatively cheap. There is probably an engine in there somewhere...
