Replacing Rod Ends
Per
Update by Per Schroeder to the LeGrand Mk 18 project car
Oct 27, 2010
Sponsored by
The old rod ends were worn, and we could feel that several had some play in them. Not good for a suspension!
While the trailing arms were off the car, we stripped the paint from them and added a new coat.
After we had to replace a rod end at the Solo National Championships, we took a good long look at all of the rod ends in our LeGrand’s suspension. We decided to replace every single one—that was the only way we could ensure we’d have a solid foundation going into our 2011 racing season.
We chose an old favorite of ours, Aurora Bearing Company’s alloy-steel PTFE-lined rod ends, for most of the suspension joints. The car is mainly held together by the 3/8-inch versions, but there are several larger and smaller sizes. We counted 22 joints in the rear suspension alone.
Once we have the car back together, we’ll need to do a full alignment and “squaring” of the car.
Comments
Gonzo_Bmod
Gonzo_Bmod Reader
10/27/10 3:38 p.m.
This all looks good, BUT now there is nothing left on the car to blame if you don't clean-up at every event!
Mine has only 14 if you don't count the ones on the swaybar links, 18 if you do.
Per Schroeder
Per Schroeder PowerDork
10/27/10 5:05 p.m.
Sunspots, alien abduction, cranial-rectal inversion—there are plenty of things to put blame on.
turboswede
turboswede GRM+ Memberand UltimaDork
11/1/10 7:22 p.m.
My only concern with the PTFE lined units is that they might be more sensitive to dirt comtamination and therefore prone to have a failure in the PTFE lining, which could cause the joint to become sloppy.
Sponsored by
GRM Ad Dept
eRZT8b7dep5ciMEYP2cAIMMncNF7LGIhQ9yOEliUYWPWLUNMF8WrsLRADEBTAgY0
