Sputter, Sputter
David S.
Update by David S. Wallens to the Honda CRX HF project car
Jun 22, 2008
Sponsored by
Our CRX isn't feeling so well today.
At a minimum, looks like we’ll move the Hondata ECU swap to the front burner.
After running like such a champ lately, the CRX started missing while at cruising altitude. It would clear up once under load.
We did some research, and looks like our P28 ECU should have two oxygen sensors, one for cylinders 1 and 2 and another for 3 and 4. We think we just have the one sensor, but we just started working on this problem. At a minimum, looks like we’ll move the Hondata ECU swap to the front burner.
Comments
jdm_Trex
jdm_Trex
9/15/08 3:51 p.m.
why not chip the ecu using a chip kit from phearable.net ? just use the basemap that comes custom made to disable the secondary O2. if not are you going with S300?
HonMaster
HonMaster
12/12/08 4:09 p.m.
I told the guys at ECUmods.com your project. They would be more than glad to sponsor you on this project build. Contact them at (832)798-0000 they are located in Houston and will ship out to you guys.
Sponsored by
GRM Ad Dept
lgN6TliIUBQoHjhv0er9tbF2C5CAsF0RX28uAOKWsBLiLRKMYnXDWWVriX1afQ9Q
