A New Heart for the Turbo Miata
Tom
Update by Tom Suddard to the Mazda Miata project car
Mar 30, 2017
Sponsored by
Oops. After dropping all its oil, our Miata's engine was down for the count.
Pictured: Not what you want your engine bay to look like days before the big race.
From left to right: The spare 1.6 that we thought was a 1.8, the blown 1.8 that was in our race car, and a Chevy V8 that we were sorely tempted to cram in with a welder while we had the tools out.
Fortunately, Treasure Coast Miata came through with a good used 1.8. It only took us a few hours from phone call to new engine in our hands.
We transferred the accessories from our old car, like the starter, CAS, and Flyin' Miata clutch and flywheel.
We also threw a volley of basic maintenance at the new engine, since we didn't want to waste a race entry due to a broken timing belt or a leaking water pump. Treasure Coast Miata had all of the new maintenance parts in stock, too.
Also on the to-do list: add a turbo oil return line to our new engine's oil pan.
We also made sure to swap our larger Fuel Injector Clinic injectors over to the new heart.
As the manual says, installation is the reverse of removal.
It was time to start connecting things. We're hoping this Remflex exhaust gasket fixes our persistent leak between the turbo and manifold.
The cause of the last engine's demise: Our turbo oil feed line melted. We're hoping that a slightly different routing and a strong dose of insulating wrap will cure this issue.
That looks much better–no more oil line-on-exhaust action.
While we had the engine out, we changed the transmission and differential oil just to be safe and to check for wear. Redline's magic sauce seems to be keeping everything happy.
We did notice one torn CV boot, though. Treasure Coast Miata supplied a few used replacements.
Oh no! Before we could start our new engine, water started pouring out. We dove back in to find the issue.
Note to self: Don't change water pumps at 2 a.m. This gasket was installed incorrectly. We put on a new gasket and buttoned everything up.
After a few nights of work, we had a running race car again. Time to clean the garage, bolt the wheels on, and load up for Daytona.
Success! Once the car was running again, we plugged our laptop into our MegaSquirt PNP 2 to check everything and set the timing.
While the car was apart, we changed from the stock fuel pump pickup to a Holley HydraMat. This magic screen prevents our pump from sucking air during hard corners.
After a flawless endurance race, our project turbo Miata blew its engine with the most inconvenient timing: while being moved between shops during our pre-race prep. That next race takes place this Saturday.
We diagnosed the problem as a failed turbo oil feed line, and started prepping our spare engine for installation. Oops: One look at the engine, which had been sitting in the back of a shed for years, and we realized it was a 1.6-liter Miata engine. Besides being down on displacement, few of our existing accessories would bolt on. So we started searching for a replacement. Fortunately, we didn’t have to search hard: Treasure Coast Miata had a good used 1.8-liter Miata engine in stock, and we had it the very same day.
Check out the slideshow for a step-by-step of the engine replacement. After a few nights in the garage, our Miata is back up and running. We haven’t had a chance to do any on-track testing, though, so we’re going into Daytona blind. Wish us luck on Saturday!
Watch the pages of Grassroots Motorsports for the full project car series. Subscriptions start at just $10.
Comments
codrus
codrus GRM+ Memberand SuperDork
3/30/17 2:07 p.m.
Looks like there's a V8 over on the right that would fit!
3/30/17 2:23 p.m.
Might take a little longer to install.
dean1484
3/30/17 3:17 p.m.
Has anyone stuck a Rover V8 in a Miata?
rslifkin
rslifkin Dork
3/30/17 3:22 p.m.
Keith Tanner wrote: Might take a little longer to install.
Eh, just line it up, set it in there and wiggle until it fits, right?
3/30/17 4:10 p.m.
That's what SHE said! Wooo!
dean1484 wrote: Has anyone stuck a Rover V8 in a Miata?
Oh yes. Not so often in the US, but there are a few in the UK.
DeadSkunk
DeadSkunk UberDork
3/30/17 5:17 p.m.
In reply to dean1484:
The president of my local Miata club owns a Buick or Olds 215 powered NA . The engine was a NOS unit, squirreled away in someone's garage before being installed in the Miata
TiggerWelder
TiggerWelder Reader
3/30/17 7:02 p.m.
Keith Tanner for the Win!!!
I have a '94 NA8 with about 200,000 on it, it was slightly overheated leading to some white smoke. Put a new headgasket on with new bolts, lasted about a month before it started puffing again, and I pulled it. Crank has been JB welded to fix a key way issue. I will let it go pretty cheap.
frenchyd
frenchyd Reader
4/2/17 1:24 a.m.
There is a Jaguar V12 powered Miata running around in Australia
hobiercr
hobiercr GRM+ Memberand Dork
4/2/17 1:12 p.m.
So, what happened at Daytona? Did the new motor fail or was it something else?
4/2/17 1:17 p.m.
I thought it was in the US. That's the one that keeps changing hands because nobody can really make it work, right? :)
Sponsored by
V8 Roadsters
Aobd8c0MA1hx2vRJ3QW0k6zKOc123MGEMFdJ86KsidnRxN3sWtopFw0rVU5Pp46B
