SRT-4 Suspension
Per
Update by Per Schroeder to the Dodge SRT-4 project car
May 13, 2004
Sponsored by
The new front anti-rollbar (on top) is 26mm vs the stock 24.5mm.
The new camber bolts do not have this knurled section. This allows more "slop" in the joint and you can get a larger range of adjustment.
After a hectic few weeks, we got out to the garage last night and started work on the SRT-4’s suspension. The anti-roll bar from a PT Cruiser convertible and the camber adjustment kits worked fine.
However, the Dynamic Suspension front and rear struts will not work for a stock class car, as the free length of the shock is too short by over an inch both front and rear. We’ll be investigating other shock absorber fitments.
Now, we need to get the car aligned, we’ll be starting out with the maximum amount of negative camber in the front, 1/8” toe out and for the rear, zero camber and zero toe.
Maximum negative camber in the front” wound up being just .5 degrees. We’re pretty underwhelmed by the adjustment available with the factory camber bolt kit. With the toe-out in the front and zero toe in the rear, the car does seem much more willing to turn in.
Comments
Sponsored by
GRM Ad Dept
aZD4WUlnJgZ7GBaKEF1bDEM2fjTppyKgrFWtHNFocUFB3cbfAs1QyOiJVt9mcjvM
