Started on April 27 by deutschman
1984 BMW 325e
1984 325e -M20b25 (SSSquid Tuning chip) -Stock 5 speed -373 LSD Diff (need to change for longer 2nd gear) -Condor Speed Shop drive train mounts -Z3 1.9l steering rack (2.7 turns lock to lock linear rate) -Catuned Coil Overs (7KG Front/ 8KG Rear, 36 way adjustable dampening, adjustable ride height, camber plates) -Ireland Engineering 25mm front 22mm rear sway bars -Condor Speed Shop solid bushings -Ireland Engineering rear camber/toe weld in tabs -TIG welded group A stile half cage tied into the rear strut towers w/ a battery box -Momo X-Large Super Cup Seat (driver) -e21 Sports seat (passenger) -G-Force 5 point harnesses -MOMO Monte Carlo wheel -Sparco quick release -TRM C1 15x8 wheels -Dunlop Direzza ZII tires -rperformance e30 trunk spoiler
Join Free Join our community to easily find more reader's rides.
Add your comment
See more
AGvcMk16ApI21FMxCwB1ss7WbXKULqBIOHaADQhPWCFN2CxJyOMl6CONkKe6uDxJ
