Does price matter when it comes to choosing a torque wrench?
J.G.
By J.G. Pasterjak
Jan 22, 2025 | Torque Wrench | Posted in Shop Work , Buyer's Guides , Features | From the Aug. 2019 issue | Never miss an article
Photography by J.G. Pasterjak
[Editor's Note: This article originally appeared in the August 2019 issue of Grassroots Motorsports. Prices have been left as they originally appeared in print.]
That click–so familiar to anyone who’s spent time getting their hands dirty in the garage. That satisfying little pulse in your hand that signals a job well done. It’s a welcome piece of audible and tactile feedback to enthusiasts everywhere.
But how good is your torque wrench? And how much should you trust it?
To help answer that question, we tested a sampling of both new and respectfully used wrenches from across the price spectrum. We also borrowed a digital testing device from our local Snap-on distributor.
This tester, officially called the Electronic Torque Digital Checker–½ and ⅜
Inch, reads the maximum torque applied to the input shaft in either peak or continuous mode. Snap-on says it’s accurate to 1 percent in both directions, and we found it easy to use.
Our methodology was to perform several tests at two different torque settings for each wrench. Using the Snap-on device, we tested most of them at one-third of their maximum torque value and again near two-thirds. Then we repeated those tests with a 6-inch extension in place to reveal any variation from just the wrench and socket. To come up with our accuracy figure, we compared our torque measurements against the torque setting. We also evaluated each wrench’s quality and usability.
We know you really just want to skip ahead and find out the “winner,” but we urge you to think beyond that. Our goal is to show the accuracy found at various price points. But first: Why do you need torque wrenches, and how do they actually work?
Torque 101
When we talk about measuring fastener torque, what we really want to know is the clamping force: How tightly are two surfaces smooshing against each other under a connection secured by threaded fasteners? This is one of the critical forces engineers consider when they design something.
Unfortunately, you can’t directly measure clamping force. Doing so would require some sort of sensor sandwiched between the two objects, which would naturally conflict with the mission of pressing them together.
So we do the next best thing: extrapolate clamping force via the amount of rotational force the threaded fasteners are exerting–also known as torque.
Click, Click
Torque wrenches–at least the “click” types that we’re mostly dealing with here–all work similarly. They’re multipiece designs featuring a hinged head near the end of the handle.
Without tension, the head would be free to flop back and forth, but the adjusting device–one calibrated for the desired amount of torque–places a preload on that head. Usually this is done via a ball-and-spring arrangement featuring a detent or similar load-based positional retention system.
When the user overcomes the maximum preload of the retention system, the head breaks away from the retention device and the handle moves independently of the head. This causes the “click” familiar to anyone who has ever used a torque wrench.
Torque wrenches are calibrated at the factory, and just about all of them–even the cheap ones–come with a calibration form containing some sample set torque values against the actual measured values. These should be within the manufacturer’s claimed accuracy for the wrench. (And if they aren’t, the wrench probably won’t leave the factory.)
This data allows the user to build a profile for the wrench. For example, if the testing shows that the wrench always produces 2 percent more torque than the desired setting, then the user can set the desired torque 2 percent below the recommended setting. Or just live with the extra oomph.
Since these are mechanical devices subject to wear, most decent torque wrenches can be recalibrated. Sometimes this takes the form of a different rate spring holding the detent mechanism; other times it’s a simple preload adjustment via a hidden screw. Premium wrenches typically have calibration guidelines in their manuals. (You totally kept the instruction manual, right?)
But you also have to know how accurately your wrench is reading, and for that there’s test equipment. The Snap-on torque checker we used retails for $550, but any tool truck should have one on board for customer use.
Each wrench manufacturer has specific recommendations for calibrating its equipment, but typically you should calibrate a wrench every year, or every 5000 cycles, or after any major trauma (meaning dropping the wrench on a concrete floor, not losing $2500 in an ill-advised hockey bet).
SONIC TWO-WAY TORQUE WRENCH
sonictoolsusa.com
Sonic Tools is new to America, as the company arrived in our market early in 2015.
  • The feel of the Sonics is among the best in our comparison lineup, and the action of the adjustment lock is positive and definitive.
  • Both the n/m and ft./lb. scales are off center and slightly distorted by their window displays, making them a bit hard to read.
  • Like most of the wrenches in our test, the Sonics had better-than-claimed accuracy.
FINAL THOUGHTS: The plastic grip and textured finish beam feel nice, although we suspect the grip will get dirty sooner rather than later with heavy use.
USAG TORQUE WRENCH
griotsgarage.com
Griot’s Garage now carries tools from USAG, an Italian firm dating back to 1926.
  • These are scaled only in n/m, which may limit their appeal for some users.
  • As accurate as any wrench in the group and feel great in the hand–but at those prices they’d better.
  • Very comfortable handle.
FINAL THOUGHTS: If you can live without a lb.-ft. scale and don’t mind the price, these are worth a look, but others we tested provide more bang for the buck.
ICON TORQUE WRENCH
harborfreight.com
Earlier this year Harbor Freight launched Icon, billed as its premium tool line.
  • The stamped scale can be slightly hard to read, but it’s better than the stamped scale on most low-end wrenches.
  • The all-chrome construction doesn’t feel quite as nice in the hand as the plastic-gripped wrenches, but it should clean up better and for longer.
  • Great accuracy, great action, smooth 90-tooth ratchet, and a great price. What’s not to like? Very little, actually.
FINAL THOUGHTS: If we had to buy a torque wrench tomorrow, we would choose one of these Icon pieces, hands down.
QUINN DIGITAL TORQUE ADAPTER
harborfreight.com
This battery-operated device, purchased via Harbor Freight, turns a ratchet into a digital torque wrench.
  • Accuracy wasn’t great, but the actual accuracy was within that claimed by many common torque wrenches.
  • The lack of a mechanical “click” means it can be tricky to use, especially at low torque settings.
FINAL THOUGHTS: For less than $30, it’s probably not a bad addition to your toolbox, but you probably won’t want to use for extremely sensitive assemblies.
KOBALT ½-INCH DRIVE PROGRAMMABLE ELECTRONIC TORQUE WRENCH
lowes.com
Kobalt, launched in 1998, serves as Lowe’s house brand.
  • The digital readout is highly accurate.
  • The lack of mechanical release when torque is achieved means the user has to develop a feel for the wrench and listen closely to the audible warnings.
FINAL THOUGHTS: Sadly, there’s not a compelling reason to recommend this wrench when there are so many other good, less expensive choices out there.
PRECISION INSTRUMENTS SPLIT-BEAM CLICK WRENCHES
torqwrench.com
We borrowed this tool from a professional mechanic friend, and he admitted that it was high-mileage and due for a tune-up.
  • While it was the least accurate in this test, it was also the most consistent. Properly calibrated, in theory, it should be up there with the best of them.
  • The dual-beam action feels nice and breaks away cleanly when proper torque is achieved.
  • The dial scale is also easy to read and easy to adjust.
FINAL THOUGHTS: Thumbs up for a quality piece.
THAT $20 TORQUE WRENCH THAT EVERYONE OWNS
harborfreight.com
We also tested a couple of those ubiquitous $20 torque wrenches that can be found at Harbor Freight, Northern Tool, Tractor Supply and Walmart.
  • The stamped numbers are a bit hard to read, and the ratchet and breakaway action doesn’t match that of the premium wrenches, but what the hell do you want for $20?
  • Accuracy was darn good for the money. We tested several of these and never found one more than 4% out of whack. Some read within 2%.
FINAL THOUGHTS: Everyone should keep one of these in every toolbox or trailer and use it for the less sensitive stuff. Plus, it’s a great loaner. Think of it as a hammer that actually does some fairly accurate torqueing.
Want more articles like this? You’re only seeing a fraction of our content on the website. Read it all in the print edition of Grassroots Motorsports. Subscribe now.
Join Free Join our community to easily find more Torque Wrench articles.
Comments
Floating Doc
Floating Doc GRM+ Memberand UltraDork
3/2/20 9:42 a.m.
I'm using a 1/2 inch Craftsman click to torque wrench that I bought new in 1992 for a head swap on my 302 Ford. I also have the smaller inch-pound, 3/8 inch version of the same wrench, but it's hardly ever been used.
I don't do much wrenching any more, so I only use it for the frequent wheel changes on my ES Miata (up to several times per month).
I don't know how off my actual torque values are, especially with an adaptor for the 3/8 inch socket that I use, but I figure that at least they're probably all consistent when I tighten down my wheel nuts.
I asked a Snap On driver/dealer about calibration of my torque wrench, he would hardly speak to me.
I have one of the hammer store electric adaptors, but have never used it for anything.
I'd like to have these tested, but not sure how to proceed. I looked into sending them off for calibration several years ago, but it was pretty costly, so I didn't follow through. Suggestions?
BTW, it's pretty sad that Craftsman is so dead that they weren't even in the test.
L5wolvesf
L5wolvesf Reader
3/2/20 10:11 a.m.
I have a HF 1/2 in torque wrench I got in the 80s (1980s). I've used it most often for wheels (at home and at tracks) but have done engines too. I've had the calibration checked a few times and it has never varied by much. It has been done by these guys who are all over the US IIRC.
Correction - just in the west
https://www.nationalcalibration.com/w/
Vigo
Vigo MegaDork
3/2/20 10:51 a.m.
I'll honestly click a $20 HF torque wrench on the most expensive thing you can find me. I think people's trust of higher-priced torque wrenches and distrust of cheaper ones are EQUALLY unfounded. I don't trust ANY of them to be any better than 5% anyway. And that's..completely adequate. It's more like $10 with a coupon, too!
Floating Doc
3/2/20 11:01 a.m.
Vigo's post does bring up a relevant question: is within 5% adequate?
I used that same Craftsman torque wrench for an engine swap and a couple of head swaps on the same car later on.
There's lots of variables when it comes to blown head gaskets, but I went through a few on the next engine.
L5wolvesf
L5wolvesf Reader
3/2/20 11:16 a.m.
Good question
https://www.pcsllctn.com/5-reasons-why-your-torque-wrench-needs-to-be-calibrated/
Trent
Trent PowerDork
3/2/20 11:29 a.m.
Most tool trucks have a self service torque wrench testers on board. If you know any one who works at a place they regularly stop they should be able to test them for you.
I had the trusty Harbor Freight 1/2" drive torque wrench for years. After I had 3 head gaskets fail on my mini i tested it on the Snap-on truck and when set to 100ft/lbs it was clicking at 70.  I chucked it in the scrap metal bin.
I suppose I should replace it but I just borrow the shop techangle for now.
AnthonyGS
AnthonyGS Dork
3/2/20 2:33 p.m.
In a previous life I was a nuclear mechanic for the US Navy.  As part of my continuing education, I went to instrument and tool calibration school.  I also did torque testing for our torque wrenches and torqued a few bolts and nuts in my day.  The nuclear Navy has a huge distrust of click type (micrometer) torque wrenches and strongly prefers dial indicating ones or even beam types.
Other advice is to always use a wrench so that you torque value falls between 15-85% of the wrenches range.  It also needs a valid calibration sticker.
And yes 5% is fine.  I'd be more worried about calibration than brand.  A calibrated cheapo is better than an uncalibrated expensive tool.
The only torque wrenches I've ever bought that had calibration data are the two CDI torque wrenches I got last year.  I shoukd probably get a torque tester or find one near me that I can use on e a year or so.
Vigo
Vigo MegaDork
3/2/20 10:52 p.m.
Possibly a more relevant question. Do you think manufacturers would subject themselves to the ludicrous suffering they would endure if they built pretty much any fastened assembly within 5% torque of failure and then sent it out into the world of real life dealership techs?
I'm sure there are plenty of cases when 5% isn't enough. But they don't pay auto techs enough for 5% to not be enough.
AnthonyGS
AnthonyGS Dork
3/3/20 12:20 a.m.
In reply to Vigo :
I understand what you are saying but +/- 5% of torque is way different than a 5% failure rate.  A torque rating is specified in order to generate a sufficient clamping force.  It's also spec'd knowing the fastener can take all of that and then some by a pre determined safety factor.  In typical mechanical engineering that safety factor is 2.0, or 100% more than the designed load of the mechanical item.  Civil engineering may use even higher safety factors.  In the previous case, the problem arose when the torque wrench was reading 30% low.  That sounds pretty legitimate to me.
Getting the exact torque also depends on cleanliness, specified lubrication, etc.  How many people do you know that chase threads and use the correct lubricant before torquing fasteners?  This alone can cause for more than +/- 5% torque.  I don't know many auto techs that get paid enough to go to this kind of trouble.  Some do, but most do not.
For example most lug nuts are torqued 75-100 ft-lb in my experience but that's a clean stud and fresh lug nut.  How many people do you see torquing beat up rusty studs with mangled nuts?  I don't chase threads myself, but do check them for cleanliness and keep wire brushes handy.  If I'm torquing head bolts though, I go to a lot of trouble to chase, clean threads, and use specified lubricant (in some cases it is none or dry).  In the nuclear navy they had a special lubricant that was used on almost all fasteners and required to get the correct spec.  It also prevented galling.  Once galling of your fasteners starts, you will never get to the correct clamping load no matter how well your torque wrench is calibrated.
I actually got irritated during study for my mechanical engineering degree, because so many engineers don't understand nuts and bolts..... If you want to be beat down with the details the mechanical engineer's handbook  is heavy reading, but good reading.
Needless to say there is a lot more to the puzzle than having a torque wrench and getting a torque reading within plus or minus a given percentage on that wrench.  Thanks goodness most stuff is just overdesigned to compensate.
ChrisLS8
ChrisLS8 New Reader
3/3/20 1:21 a.m.
I have a HF 3/8 and 1/2 clickers, a CDI flex 3/8, and Quinn digital 1/2.
The quinn is made by Eclatorq same as the Kobalt, made in Taiwan and I like it. Also does angle if you need it to.
All of em except the quinn have rebuilt motors with zero problems.
MgWLz9MSbxoW6mFLuZQ5izMO84jxdDVcYq2gpCLiYcNumBGEuiDzui9aGgDGPCul
