markwemple
markwemple Dork
11/26/15 3:43 p.m.
If i found a blown getrag how much would the guts from a svt cost?
markwemple
markwemple Dork
11/26/15 3:45 p.m.
The cost of the swap includes 2 new axles, mount, cables, flywheel and clutch. You can see how this gets expensive. Plus its at least a day's work.
DeadSkunk
DeadSkunk UltraDork
11/26/15 5:07 p.m.
I've seen Focus SVT transmissions for $250-300. Yes, the rest does tend to add up. Just seems like a shame to walk away from cheap MINIs.
markwemple
markwemple Dork
11/26/15 5:25 p.m.
Cheap until you fix it. It still may be cheap but, it needs a window regulator, a/c doesn't work, coolant tank was low, stitching is coming apart on one seat, headliner is beginning to droop, etc. And since you can't drive it, who knows what else may be needed. Not trying to dis it. Just being straight about its condition.
markwemple
markwemple Dork
11/26/15 5:27 p.m.
Oh and on the swap I forgot to include starter, slave cylinder and clutch hose.
DeadSkunk
DeadSkunk UltraDork
11/26/15 5:30 p.m.
Parts car......
http://harrisburg.craigslist.org/cto/5333308581.html
DeadSkunk
DeadSkunk UltraDork
11/26/15 5:32 p.m.
http://washingtondc.craigslist.org/doc/pts/5331205734.html
markwemple
markwemple Dork
11/26/15 5:38 p.m.
Sent messages to both. I'd be more inclined to fix the Harrisburg car as it's body may be cleaner and, well, it's an s.
markwemple
markwemple Dork
11/27/15 1:30 p.m.
Still waiting. Question is, would you trust a mini with 200k? The OP car has 132k but is a 1 owner.
markwemple
markwemple Dork
11/27/15 7:41 p.m.
Received pocs of the s. Looks really clean. Finding out more.
markwemple
markwemple Dork
11/28/15 9:20 a.m.
Only thing he ever did to the cooling system was to flush it. He had installed an underdrive pully system.
Datsun310Guy
Datsun310Guy PowerDork
11/28/15 10:30 a.m.
I see there are a few of these in Chicago craigslist with toasty auto trannys.
markwemple
markwemple Dork
11/28/15 11:18 a.m.
There's a class action against bmw for those cvts
markwemple
markwemple Dork
11/28/15 8:15 p.m.
Anyone else with input? Not sure what to target on the cooling system issue
markwemple
markwemple Dork
12/1/15 5:19 p.m.
The OP is going to rebuild it after all.
Lz0gDeasulsQ1MJ4UKue9hcDEdHHj4IqeiwTFbndPyFGDEjCfuReuOy6JUd4Qf1M
