oldopelguy
oldopelguy Dork
8/5/09 8:58 p.m.
1.5L VVTi DOHC engine with 5-speed from rollover '04 Scion xA. Had @50k on it, made 107hp and sure doesn't weigh a lot. Same engine in the Echo, Scion xA and xB, Yaris, and with different cams the Prius.
I unbolted everything from the car, every last bolt, and you can have anything you can convince me the engine needs to run for $300 and coming to get it out of the storage unit.
CarKid1989
CarKid1989 Reader
8/5/09 10:41 p.m.
wow. this is odd. just wasnt expectin somethin like this hmmmm
jwdmotorsports
jwdmotorsports HalfDork
8/6/09 12:09 a.m.
Do you have all the parts to convert an automatic car over to 5-speed (pedals, master/slave cylinders, etc.)?
My (used to be the wife's) Echo is automatic.
dxman92
dxman92 New Reader
8/6/09 12:37 a.m.
This might be a long shot but do you have a rear sway bar from the Xa/
oldopelguy
oldopelguy Dork
8/6/09 11:18 a.m.
I do have all the pedals and everything, and if it had a sway bar then I have that too. I'll have to do some digging to see where the sway bar went; I'm building a trailer with the rear axle so it'll have the same 4x100mm bolt pattern as my Opels and not sure where all the rear suspension stuff ended-up.
bYuoBuZRg9YRQRhGYxkq0gI49PWCsh4J06TdJVJecTyKSZ39F9VDqsL96LSiZRHZ
