engine: 5.3 from 2001 silverado, 40k miles.
trans: 4l60-e from 2003 silverado 20k miles
engine has LS1 intake, LS6 fuel rail(returnless), brand new LS1 car injectors. truck accessories with idler pulley relocation bracket to run the car intake.
both the truck oil pan (used) and f body oil pan(new from gm) are included. with matching pick up tubes and windage trays.
truck manifolds, f body manifolds with MAC offroad Y pipe, AND stainless steel F body long tube headers are included.
S&P stand alone harness and PCM included - simple 4-5 wire hookup and you are running. (used)
Corvette fuel filter with integrated fuel pressure regulator included(new)
LSx to SBC motor mount adapters included, and i countersunk all the bolt holes that mount them to the block so you can put any motor mount on without interference. allen head bolts included.
power steering pump, air compressor, starter, alternator all included.
brand new water pump installed straight from GM for an 07 6.2 - the angle of the outlet clears the car intake manifold throttle body location
new lokar LS throttle cable @ 36" long
you know you want it. ready to drop into just about anything with the oil pan and exhaust options.
brand new F body front o2 sensors
o2 simulators to replace rear sensors
coil packs included(need mounting brackets) as are corvette fuel rail cover that i also bought new from GM.
i paid $1200 for engine, $300 for trans, $800 for harness and pcm, and have about $2000 in all the extras. engine swaps add up. i'm going to stick with my gen1 small block stuff for a while.
price: $2011 for EVERYTHING
