Treasure Coast Miata
Treasure Coast Miata New Reader
10/7/13 3:43 p.m.
Treasure Coast Miata is now offering a New Aftermarket Rear Finish Panel for '90 - '97 Miatas
Special pricing can be found at;
http://treasurecoastmiata.com/i-11969597-new-aftermarket-90-97-rear-finish-panel.html
This affordable, Replacement Rear Finish Panel is made from ultra-durable ABS plastic, it is an OEM quality aftermarket panel that easily replaces your age brittle, broken or cracked rear panel. This new panel has a bit more flex and the alignment holes for the factory emblem are removed on the outside (for that smooth look), but is still marked on the backside so you can drill in the correct spot to have the emblem in place. Factory mounting locations are used so it fits perfectly without any modifications.
Let Treasure Coast Miata be your one source for all your used Miata parts needs
TreasureCoastMiata.com Your Used Miata parts Super Store
M8Kw8rJMbwl8EFFUBWeIs6aI558cs31KNTcFournAylcwkMkjwCrzdetIXdTL0ga
