1 ... 47 48 49 50 51 ... 53
java230
java230 PowerDork
6/7/24 9:05 p.m.
In reply to NOHOME :
That is 3/4 aired up. It's low.
And it started and drove back into garage!
Dusterbd13-michael
Dusterbd13-michael MegaDork
6/7/24 9:11 p.m.
berkeleying WINNING!!!
Mr_Asa
Mr_Asa MegaDork
6/7/24 10:41 p.m.
Awesome.  Any clue what may have been preventing it?
java230
java230 PowerDork
6/8/24 11:12 a.m.
In reply to Mr_Asa :
Low battery I am Hoping? I think the tbi might be picky on voltage?
I think my jb weld fix isn't fixing....
Dusterbd13-michael
6/8/24 11:18 a.m.
Tbi hates under 10v
And sucks about the pan. More outside pictures please!
java230
java230 PowerDork
6/8/24 11:38 a.m.
Yeah it could see it squirting, then stopping and crank slowed. Picked up new battery last night. Did not get to install yet.
Which reminds me, I should really get an air filter....
It's deafiningly loud. And I think timing is miles off still. Gas pedal is also very sticky.
NOHOME
NOHOME MegaDork
6/8/24 12:09 p.m.
In reply to java230 :
Noisewise, you might have the same issue I had with the Molvo: When it had the perfect ruble for the the spectators as I drove by, it was horrible loud and drony inside the big box that is a station wagon. In everyone's opinion, the car is too quiet now.
java230
java230 PowerDork
6/8/24 12:09 p.m.
Well mine is open headers ๐Ÿ˜‚
Recon1342
Recon1342 UltraDork
6/8/24 12:26 p.m.
That may have something to do with it...
java230
java230 PowerDork
6/8/24 1:09 p.m.
In reply to Recon1342 :
Yeah.... A little.
Yeah or no? I have had this 8 ball for literal decades waiting to be a shift knob for something.
wawazat
wawazat SuperDork
6/8/24 1:24 p.m.
Great news that it started.  Fuel injection systems HATE low voltage.  ECU needs the jolt to wake up and get to work.
wawazat
wawazat SuperDork
6/8/24 1:24 p.m.
Oh, yes please on the 8 ball shifter!
java230
java230 PowerDork
6/8/24 1:51 p.m.
Well brake lights do technically work. But they are crazy dim. Prob bad ground is my guess.
Turn signals, would they need the load from the front as well to trigger an old school flasher relay?
Edit: tail and driver side brake works. Seems like contacts on bulb and or housing are getting pretty warn. Wiggling makes things work then not etc.
java230
java230 PowerDork
6/8/24 9:07 p.m.
Door handles, check. They are beat to hell from living in my tool box for the last few years. But they work.
Tail lights, brake lights (intermittent?) and turn signals (sometimes?) check.
java230
java230 PowerDork
6/9/24 12:45 p.m.
Setting timing.... To get close just set pickup to #8 at TDC.
Once warm, it should be 0 degrees with the advance unplugged.
Timing light should shine on 0d....
What's the easiest way to find TDC??
It's running. But I'm pretty sure it's off.
So the tbi instructions I have mention a timing bypass.... Tan wire with black stripe, but that appears to be in the main connector to me.
It's sitting just over 21deg at idle and advances more with throttle application currently.
java230
java230 PowerDork
6/9/24 1:11 p.m.
Never mind, I found the advanced disconnect connector. It's set to 0° now. Or it's 180° off.
One of my fancy stainless wire DIY hose clamps is leaking. But I guess it means the cooling system pressurized?
java230
java230 PowerDork
6/9/24 2:14 p.m.
Timing is set. It automatically advances to 15 at idle .
I took the leaf blower to the interior. It's a bit better. And smells like a 70s smoker car now that it's out in the sun ๐Ÿคฃ
I reinstalled all the door seals.
Indy - Guy
Indy - Guy UltimaDork
6/9/24 2:32 p.m.
That's why God invented exhaust cut-outs.
My Jaaaag had them.  It was absolutely the best of both worlds.
java230
java230 PowerDork
6/9/24 3:23 p.m.
In reply to Indy - Guy :
I put them on my Tundra ๐Ÿ˜
Indy - Guy
6/9/24 3:28 p.m.
๐Ÿ‘๐Ÿ‘
Is the Travel-All getting them too?
java230
java230 PowerDork
6/9/24 3:31 p.m.
TBD. I may down the line. Easy enough to cut in later.
On that.... Cats or no cats? I won't have a back window for awhile. So may be worth it....
java230
java230 PowerDork
6/9/24 8:42 p.m.
A few hours of zip ties. Trying to Tidy the wiring mess..... Still. Not. Great. But mostly away from spiny and hot bits.
Added Amazon special puke tank. It's nicely welded stainless actually!
RacetruckRon
RacetruckRon GRM+ Memberand SuperDork
6/10/24 1:58 a.m.
Do you have a link for that puke tank?
java230
java230 PowerDork
6/10/24 8:35 a.m.
In reply to RacetruckRon :
I actually tried to find it when you were asking.... I bought it so long ago that seller isn't on Amazon anymore. But there are lots of others that look the same for about $25.
This one looks identical. The inlet and overflow ports are tiny tho FYI.
https://amzn.to/3XjlfRE
java230
java230 PowerDork
6/10/24 7:47 p.m.
Well I won today. 3 trips to the dol, one to the department of revenue (dol has no records of travelall and was trying to value it at 24k). I have permanent plates!
So eyeball alignment, toe out or in better?
CvEHRSKDA6E7i4dOzTE7EWh6eXoLYeUGBiu9ZNh71ST2KMjJ4Ab9YqXpcFhGlytA
