I ran out this morning and picked up a 750lb engine stand at a local auto parts store. I wanted a heavier-duty foldable stand, but Harbor Freight didn't have it when I went down last weekend and I don't really feel like waiting, since the engine is annoying sitting on a dolly taking up way too much floor space and hard to get to.
So, after lugging the crane out of the shed out back (fun....in the deep grass and uphill, all the way around the house :( ), put the engine up on the stand. It didn't fall or anything, so I guess that's good, lol
Since I'm really tired of lugging the crane all the way around the house to use it, I cut down some of my "fluids" shelves so the crane can tuck in there in the last available piece of wall space in my garage. Yeah, I know it's really exciting to you, right? Well, it is to me!
ok, so on to some work. finished pulling apart the intake manifold and injector assembly. Cleaned up the IM good. The inside had...oh...about 27 years worth of gunk in there and took a lot of scrubbing and a lot of degreaser and Dawn.
This is a good time to mention that of the 10 types of degreasers I have here at the house that can be used in the basement shop sink without killing everyone from fumes.....none of them is half as good as Dawn dishwashing soap at degreasing nasty engine stuff. Most of you probably know this already, but in case you didn't....
Two of the injectors must have been leaking and some brilliant previous owner used something or other (JB weld? who knows) to seal it. Nice.
Injectors out. One has a slightly broken cap. I'll either rebuild them or get some Mustang injectors, whatever is cheaper :)
Then the mail came! My new motor mounts from Condor Speed Shop. These are the prototype M10 mounts (for the few of us on this planet who want solid motor mounts for an M10?) so I'll be installing tomorrow. They're UHMW polyethyline....so they're solid, but should absorb more vibration than aluminum mounts. Not that NVH really matters on this car.'
Putting those aside until tomorrow or Sunday, getting back to the M42. Now that it's on a stand I can start taking more stuff off. I already knew that the guy I got the engine from had cracked the oil pan at the plug and it has some JB weld there in what appears to be a functional repair. But for peace of mind I'll source another and save this one as a spare I think.
SO first the lower oil pan. Was expecting, as all M42s seem to have, for there to be an upper pan bolt sitting in the pan. There wasn't, so that's good. Unfortunately, one was simply missing. I guess a previous owner found it and took it out. The rest of the bolts up there were extremely loose (like, I took them all out with my fingers and didn't need a socket!). Again, I kind of expected that. When they go back in they'll be torqued correctly with some threadlocker for sure.
you can see the missing bolt is at the top right up inside. Just an empty hole there.
Then took the upper pan off mostly just to make it easier to clean it all up. The crank looks fine I suppose (though I am far from an engine internals guru, so not really sure what to check while I'm in here.....suggestions welcome.)
Then I spent about an hour over the big shop sink cleaning both oil pans. These things literally had 1/2" of oily gunk buildup in certain areas, so required a lot of scrubbing, wire brush, scotchbrite, etc....They don't need to look pretty, but I like working on things that aren't coated in layers of crap....
so, that's clean enough
Also started my long list of gaskets and seals to order (basically.....all of them except the head gasket, since I'm not planning to pull the head).
Next week the plan will be to pull the timing cover and figure out what else I need there (I'm going to guess "everything.")
