Ian F said:In reply to irish44j :
Maybe cut out an oval including the fill port, rotate 180 and re-weld?
My guess is the FSM method for removing the trailing arms is to drop the sub-frame, which is probably why the issue you're running into would never occur to the designers.
no doubt about it. BMW likes to do things that aren't an issue when you're charging hourly shop fees lol.
Wrapping up a few things so I can do other stuff this weekend and not be under the car....
First order of business was to check all my bolts on the rear end, snug up the axle nut, and bleed the recently-disconnected right rear brake caliper.
With the car on the ground, the difference is apparent in terms of toe and camber. Feels like forever since the rear wheels were more or less straight up.
So went from 2.5* negative to under 1* and no toe. That should substantially help out the handling of this car and make things more predictable (and grippy) on the gravel.
In addition, got in some new street tires for the car. For years I've used some old Star Specs for street driving, and in a size that is shorter than I like (for looks or for gearing) at 195/55/15, which makes for some high revs on the highway with the G240. Now that I actually have some torque, I really don't want those high revs any more lol.
Plus, the Star Specs are sketchy in these early and late-season events in the W.Va. mountains where it's often sub-freezing roads and maybe some snow. I've been towing to events recently but plan to get back to driving the car there since the roads to Panthera are a lot of fun in a car and a lot of big-ass hills that make towing tedious.
So, Tire Rack deal, plus a $50 gift card, and all told just a bit over $300 for a set of all-seasons to may door. They're not super high-performance tires (grand touring), but that's ok. Oddly, they seem to have very similar tread pattern to the BFG Comp 2 A/S I have on the Porsche. Anyhow, will get them mounted up on my Euroweaves - these are 205/60/15 by the way
And last of all, got the drill out and made some mount holes for the skidplate and got it all set up. I have a few modifications I want to do to further strengthen things for stage, but for rallycross it'll be fine, and it'll be a while before the next stage rally
Kind of scraped up my new paint while getting it all set up lol. It looks lower in this shot than it is in reality, though it IS lower than with the M42 by about an inch or so. I'll recover that with taller tires when i move all my rally wheels to 15s.
The plate is lower, but I left more pan clearance than i had with the M42. I plan to eventually add a longitudinal brace bar from the front to rear mount bars in order to further strengthen things and prevent the bar from bowing in.
