myusdmcavalier
myusdmcavalier None
9/5/23 8:53 p.m.
I'm trying to make my 2001 cavalier a little faster. It's got the 2.2 ohv (the base model motor) let's try and make it fun.
cfvwtuner
cfvwtuner Reader
9/6/23 10:05 a.m.
We had quite a bit of fun with our 97 2.2 Cavalier coupe.  We found lowering springs on Ebay, put on some decent tires, and an Addco rear sway bar.  Cut off the stock muffler and put on a Thrush Turbo muffler for some sound.  Was a blast for almost no cash
myusdmcavalier
myusdmcavalier New Reader
9/6/23 12:27 p.m.
In reply to cfvwtuner :
ill look into that sway bar, that car definitely needs one.
MadScientistMatt
MadScientistMatt UltimaDork
9/6/23 12:43 p.m.
You'll want to decide at the outset if your goal is to get the most out of the 2.2 or get the most power for your money into the Cavalier. Something like a 3.9 V6 can go for cheap although it's a bit of work to install. While adding mods to the 2.2 could either fit a goal of a little more power for a little money and effort, or a goal of specifically pushing a motor with little aftermarket to its limits. But you'll want a clear goal from the start.
DjGreggieP
DjGreggieP Dork
9/6/23 6:52 p.m.
I will echo MadScientist and say have a set plan. On my intrepid I got 'cheap' exhaust work done enough times I could have paid for the fancy custom work and muffler it has now much much sooner had I made a proper plan of what my end goal was going to be.
I very rarely see these cars anymore. There was one with a period correct aftermarket bodykit locally last year but I haven't seen it in a long time now.
kevinatfms
kevinatfms HalfDork
9/7/23 9:48 a.m.
myusdmcavalier
9/17/23 6:58 p.m.
Got new wheels today
Wally (Forum Supporter)
9/18/23 4:05 p.m.
I had thought about swapping a V6 into mine, but it was such a reliable car I couldn't see going through the work for a commuter. The turbo idea is intriguing though.  It never gave me any trouble except all the salt and the time it  took on sea water after hurricane Sandy ate through the floors and lower quarter panels.
Peabody
Peabody MegaDork
9/18/23 5:20 p.m.
From memory it came with a 52mm throttle body, maybe smaller. See if you can find a 56mm that fits.
At some point there was a switch in rocket ratio from 1.6 to 1.5, or the other way. If you can take advantage of that move and put in the 1.6's in if you havr the 1.5's that would help. Free up that exhaust
myusdmcavalier
9/29/23 9:20 p.m.
got the wheels installed today.
Curtis73 (Forum Supporter)
9/29/23 9:27 p.m.
Add boost until it explodes.  Buy junkyard 2.2 for $200 to replace it and turn down the boost until you get a combo that doesn't explode
9/29/23 9:38 p.m.
The LN2 engine is not really worth it IMO.  They are an excellent appliance, but they have weak pistons.  Turning up the power can cause them to fall apart.  Rod/stroke ratio is poopy.
LM performance has some go-fast goodies for your LN2, but by the time you spend $2000 going from 110 hp to 150 hp, your money is better spent on a $500 V6 swap.
myusdmcavalier
10/13/23 9:55 a.m.
I plan on hitting some junkyards the weekend. Im looking for the sway bar off the z24, which is the only model that had one.
iansane
iansane GRM+ Memberand Dork
10/13/23 10:05 a.m.
That thing looks like it's in great shape!
I like the v6 idea. Especially if it's supercharged.
camopaint0707
camopaint0707 Reader
10/13/23 11:14 a.m.
boost is the only way to make a cavalier faster
myusdmcavalier
10/13/23 11:48 a.m.
In reply to iansane :
thank you. Someday ill do a v6 swap, drive it for a few more years first.
myusdmcavalier
myusdmcavalier Reader
12/28/23 3:26 p.m.
figure I should ask this before the year is over, what are some suspension mods yall would recommend for my cav.
DjGreggieP
DjGreggieP Dork
12/28/23 3:59 p.m.
Check out H&R springs. I have had good experience with them.
I have also heard good things about Eibach springs.
Both should lower the vehicle a bit and have a decent spring rate to go with the reduction in ride height. I don't think either will 'slam' the car, but when I did fresh struts and H&R springs on my car, it was 1.25" lower fresh off the hoist and later settled to about 1.5" after a year or so.
Gearheadotaku (Forum Supporter)
Gearheadotaku (Forum Supporter) GRM+ Memberand UltimaDork
12/28/23 8:52 p.m.
Watch for Beretta and Corsica for a rear bar, they may fit, but not 100% sure. Convertible Cav/Sunfire should have a strut tower bar you can use. The 03-05  Cavailer LS sport may have a rear sway bar too.
iansane
12/29/23 10:11 a.m.
Don't forget a good strut/shock to go with springs. I'm a fan of Koni's. That'll help control that stiffer spring rate.
BS66sIUFr00lp0fWPbRIo4r8J0BxxvfkUXjWZPHfpRHkXmlu9Qg7AQqGYNMVFckW
