svxsti
svxsti Reader
7/20/20 7:38 p.m.
So I'm swapping out the auto trans and looking for suggestions for a manual. Engine will remain stock and will be used for a weekend cruiser, drag, autox and hopefully drifting. Mufflers and cats have been hollowed for a Zondaesque sound.
MrJoshua
MrJoshua UltimaDork
7/20/20 8:53 p.m.
Very sharp.
FatMongo
FatMongo Reader
7/20/20 9:13 p.m.
I have no idea what kind of transmission will bolt to the that 12 cylinder monster, but I would suggest looking into the possibility of a T56 / Tremec Magnum XL.
Run_Away (Wears Clogs)
Run_Away (Wears Clogs) GRM+ Memberand Dork
7/20/20 10:20 p.m.
Wiki says 389hp. Does someone make an adapter plate?
I've been reading up on the Nissan Frontier V6 manual transmissions for swap use. Apparently they're basically the same as a CD009 from a Z, but with slightly different gearing and a conventional shifter vs the goofy CD009 extension.
yupididit
yupididit UberDork
7/20/20 10:27 p.m.
I used to have a link to a company in Germany (I think) that made adapters for the m120 to  bmw gearboxes.
daytonaer
daytonaer HalfDork
7/21/20 7:49 a.m.
The zf 6 speed in the BMW 860 was also used in the c4 Corvette: however I do not know if they share a case or just common development parts. This transmission was also used in the zr1 Corvette so it is a stout unit and if can be adapted may be easier to source.
Great project, I daydream of doing the same thing!
yupididit
yupididit UberDork
7/21/20 10:07 a.m.
In reply to daytonaer :
These were the gearboxes from e39's i believe 420g and the diesel e90/92 chassis.
svxsti
svxsti Reader
7/21/20 3:26 p.m.
ZF 6 speed was my first thought, then Tremec. Any suggestions on a shop on the East Coast?
FatMongo
FatMongo Reader
7/21/20 3:39 p.m.
Might be worth a call to look up Rev Auto in Baltimore. They've made a name for themselves in rebuilding chinese MT-82s in Mustangs to a useable standard. If they cant help you, they might be able to refer you to somewhere that could.
JC1098
JC1098
7/26/20 10:46 p.m.
There's a drift guy Oliver Amon out in Poland or Czech Republic who has swapped in a manual trans in a C140 CL600.
https://www.youtube.com/watch?v=xrC-9Um_mLI
https://www.youtube.com/watch?v=82BUJW6Wvnw
No idea what he used other than "BMW bellhousings".
Very interesting idea though, will be following closely.
XWf4DyFbk6NZ4kZdUqqfcn0UWSdPbk7EUc59KIp5A9JyNa5XSruNfu2Sogo3yIsU
