1 2 3 4 ... 15
Ben_Modified
Ben_Modified New Reader
2/3/15 6:41 p.m.
Dusterbd13 wrote: You're not right in the head. #and I love it! Looking forward to seeing what happens.
Thank You!
gamby
gamby UltimaDork
2/4/15 12:32 a.m.
Ben_Modified wrote:
gamby wrote:
Ben_Modified wrote: Video of the Build so far
That's pretty awesome/wild. Aesthetically, the truck would look better with the front wheels located in the cab's god-given wheelwells, but who the hell am I to tell you what to do?! Plus, it'll look pretty wild stretched out like that and I'd assume it'll drive a bit more predictably. Regardless, looking forward to seeing where it goes.
By moving the wheels out from under the cab, I can get the cab much lower in the frame and I will not have to sacrifice room in the cabin. With the wheel wells filled in, I think that the lines will flow well. I also have a few other cosmetic upgrades planned.
Oh, don't get me wrong--this is going to be an awesome build!!!
Ben_Modified
2/4/15 1:49 a.m.
gamby wrote:
Thanks!
moparman76_69
moparman76_69 SuperDork
2/4/15 6:49 a.m.
I think you should put fuel tanks in the wheel arches instead of filling it in.
Ben_Modified
2/4/15 4:33 p.m.
Frame back half is done
Ben_Modified
2/5/15 8:09 p.m.
I decided to add some gussets to the frame joints.
Also welded the Front Spring Perch to the front crossmember while I can still flip it in all directions for a good hot weld. This perch supports the entire front of the vehicle.
Frame so far
My Build Blog website
CarKid1989
CarKid1989 SuperDork
2/6/15 10:03 a.m.
Pretty much what i had in my head since 2013...i cant wait to see this
tuna55
tuna55 UltimaDork
2/6/15 10:08 a.m.
Wow
Ben_Modified
2/6/15 7:21 p.m.
Frame is nearly done
Ben_Modified
2/7/15 12:16 p.m.
Frame is done!
Ben_Modified
2/8/15 7:07 a.m.
Started attaching suspension
My Build Blog
Lonny
Lonny New Reader
2/8/15 8:35 a.m.
You are making quick progress.
We had a 1959 VW truck when I was a kid. We hauled motorcycles and dune buggys all over Texas with it.
A friend of mine had one he called bug foot. It had monster tires and was raised almost high enough to sit under it.
Ben_Modified
2/8/15 5:21 p.m.
Sanchinguy
Sanchinguy New Reader
2/8/15 7:19 p.m.
How will you handle the steering? Hot rod style?
Ben_Modified
2/8/15 8:13 p.m.
Yes, I have a vega box with some steering shaft and a couple of u joints
Ben_Modified
2/9/15 5:44 p.m.
Front and Rear Suspension are completely connected.
NOHOME
NOHOME UltraDork
2/9/15 6:59 p.m.
You don't berkeley around much do you? I should introduce you to my friend Beer who helps me pace these projects out a bit
I like what you have done with the frame, but would be somewhat concerned about the torsional rigidity with a V8 bolted in there.
Ben_Modified
2/10/15 5:56 p.m.
Started putting together the engine/trans/rearend cradle today. Also picked up 4 trailer fenders to make 2 VW big fat tire fenders
Ben_Modified
2/16/15 6:18 p.m.
Engine cradle is done. Engine and trans crossmembers are next.
My Build Blog
SVreX
SVreX MegaDork
2/16/15 7:36 p.m.
My first car was a Splitty.
I love anything cool done with a Splitty!
Carry on!!
Ben_Modified
2/17/15 5:58 p.m.
Built a hitch into the frame and setup the rear crossmember to accept tail lights. Also made up brackets for the parking brake
petegossett
petegossett GRM+ Memberand PowerDork
2/17/15 6:45 p.m.
In reply to Ben_Modified:
Your work makes my feeble automotive projects(and welding) look like craft-sticks held together with Silly Putty. Incredibly impressive skills and vision!
Ben_Modified
2/21/15 3:27 p.m.
petegossett wrote: In reply to Ben_Modified: Your work makes my feeble automotive projects(and welding) look like craft-sticks held together with Silly Putty. Incredibly impressive skills and vision!
Thanks for the kind words and thanks for following along! Took a couple of photos of the motor and trans going in today.
Ben_Modified
Ben_Modified Reader
3/2/15 6:03 p.m.
Upper shock mounts
Ben_Modified
Ben_Modified Reader
3/10/15 5:45 p.m.
Engine and trans crossmembers are rough cut. Will smooth out and weld in tomorrow.
1 2 3 4 ... 15
9bDb9CIHyGT4C5Cn7owR4HSkCMZcjw1QzpXv3ubJr5ywsdVWqgNX5DMxPReDswdQ
