1 ... 103 104 105 106 107 ... 159
tuna55
tuna55 MegaDork
6/23/17 12:23 p.m.
Dusterbd13 wrote: Hydraulic or electric power rack?
electric power rack
Dusterbd13
Dusterbd13 UltimaDork
6/23/17 12:49 p.m.
Ok. Ill look around and see what i can find.
Rufledt
Rufledt UberDork
6/24/17 11:25 a.m.
Toyman01 wrote: I have nothing intelligent to add to the discussion. I just wanted to say I'm glad to see this pop up to the top of the page on a regular basis.
I'm with toyman on this one.
tuna55
tuna55 MegaDork
11/18/17 8:21 a.m.
tuna55
tuna55 MegaDork
11/20/17 8:55 a.m.
The big problem, which I just realized, with this solution is that I need to make enough room for a nut on the threaded sleeve below the knuckle. I guess that's not that bad.
tuna55
tuna55 MegaDork
12/19/17 9:49 a.m.
Almost a month later...
No pics today, but here is the deal. Terry borrowed an outer tie rod end and created a sleeve for me from a 3/4-16 bolt. I drilled out the taper in the drivers side spindle and tapped it likewise. Yesterday, the sleeve arrived. Tunakid #4 and I threaded in the spacer, and later, after two additional long-term guests, and their dog arrived, and unloaded everything they own which is not in long-term storage (no really, in the army between deployments) into my garage, I actually did creep back into the garage to do stuff.
After moving copious stuff out of the way, I assembled the steering on the drivers side and used the time-honored bumpsteer measuring method called "put your iphone on "compass" mode and push it against the disc while moving the spindle through its arc with a jack".
Anyway, tens of degrees of bumpsteer was measured with the tie rod on top of the spindle where the general put it. Where Tuna put it, on the bottom, with Terry's spacer, the extremely precise iphone could not detect a single degree of bumpsteer.
I will work on a more precise method, but I am obviously on to something here. I am super excited.
volvoclearinghouse
volvoclearinghouse UltraDork
12/19/17 9:55 a.m.
Yay!
xflowgolf
xflowgolf Dork
12/19/17 10:04 a.m.
Glad to see this thing still clicking along.
ShawneeCreek
ShawneeCreek GRM+ Memberand Reader
12/19/17 11:23 a.m.
Excellent work. I love it when a plan comes together.
bgkast
bgkast GRM+ Memberand UberDork
12/19/17 12:54 p.m.
Your consistent progress is shaming me to get back to my build. Keep it up!
NOHOME
NOHOME UltimaDork
12/19/17 12:59 p.m.
Always makes my day when the TunaTruck makes an appearance. More pictures please.
Pete
Rufledt
Rufledt UberDork
12/19/17 1:50 p.m.
Agreed, can’t wait to see more
NOHOME
NOHOME UltimaDork
12/20/17 6:07 a.m.
In paint by spring right? wink
tuna55
tuna55 MegaDork
12/20/17 6:52 a.m.
In reply to NOHOME :
I've said that before, eh? This spring the Honda should be primed and painted, but golly my budget is stupid.
tuna55
tuna55 MegaDork
12/21/17 8:17 a.m.
This area does not photograph well, and I had to truncate my video due to company wandering all over, but here is what I've got.
This shows the complete tie rod, hanging beneath the spindle, lower center of gravity!
I did not take everything apart, but here is the threaded spacer in the spindle
It's really quite simple. I think I have even devised a plan to measure the bumpsteer cheaply. I'll find out soon and show everyone when I've done it.
The problem now if that the swaybar hits the tie rod in its new location. The solution is that the swaybar, as designed by GM and not modified by me, will fit now. Observe.
If you recall, the swaybar originally looked like this
Please note that now the tie rod will handily pass beneath the arc of the bar. So really, the solution is to go get another stock bar from a 1996 Suburban. I only wish I could find a bigger hollow one for cheap. The stock endlink from that generation of truck (I believe 1992-1999 are all the exact same) will fit into one of the two holes already in the control arm for the style swaybar that GM used for the dump truck version of the generation I have. If you recall, those look like this.
So, off to the junkyard to get a swaybar again, measure bumpsteer to make sure it's as good as it looks, have Terry make a second spacer, and the front suspension is done.
tuna55
tuna55 MegaDork
12/27/17 9:23 a.m.
Remember how I said they were the exact same? The one from the yard (which I actually cannot recall the exact year/model) was vastly different on the ends and actually didn't fit, so that puts me back at my modified one with longer end links. I can do this though, no big deal.
I took many many videos and pictures, some of which I will share later, but the moral is that my slick idea to measure the toe did not work.
tuna55
tuna55 MegaDork
1/5/18 10:54 p.m.
Terry came through with another slick tapered/threaded spacer, so I went back, drilled and tapped the passenger side, and used red Loctite to insert it and assemble the tie rod. I also removed and reinstalled the drivers side with Loctite too. It's done!
Untitled by Brian Bassett, on Flickr" />
Now for my next trick...
I have no clue what to do with it. That's not entirely true. I want to replace the lower shaft with the typical Cherokee shaft for the rag joint elimination. That's "easy". I also want to remove the evidence of the tree shift from both inside the cabin (the hole where the lever went) and in the engine compartment (the leftover levers) and fix the flashers (broken off). I am open to ideas which are nearly free.
For some reason my phone won't send the pic of the tapered sheet metal bit in the cabin where the shift lever used to live. Use your imagination.
In other news, my nine year old today hearing about garage work at dinner said "Dad, you got your mojo back!". That was cool.
Rufledt
Rufledt UberDork
1/5/18 11:29 p.m.
Mojo back indeed!!  You have no idea how happy I was to see this pop up again
Mad_Ratel
Mad_Ratel Dork
1/6/18 12:32 p.m.
Any concern of the new fitbit for the tie rods backing out over time? I knwo you red loctited them.  Just thinking a large washer between the castle and the bits would mean it would have to crawl it's way out against something stopping it from rotating out.
tuna55
tuna55 MegaDork
1/6/18 1:35 p.m.
In reply to Mad_Ratel :
A washer on the castle but side makes sense. I can’t use one on the tie rod side though. Good call. I’ll get something going.
Mad_Ratel
Mad_Ratel Dork
1/6/18 4:06 p.m.
I do wonder about the threads pulling out of the spindle. But this should see  none of the force of a lca or uca.  So probably no issue of the threads getting ripped out.
tuna55
tuna55 MegaDork
1/6/18 6:28 p.m.
It’s an inch long 3/4-16 thread. It’s stronger than the cast iron around it. As long as it doesn’t spin out, it should be fine. The loctite should be more than sufficient to prevent that even without the washer but it’s still not a bad idea.
Mad_Ratel
Mad_Ratel Dork
1/6/18 6:53 p.m.
I was thinking more of thread pullout, but as I said, it's not teh same forces a UCA/LCA Balljoint would.
The washer should stop any loosening of the thread insert.
SaltyDog
SaltyDog Reader
1/6/18 8:01 p.m.
I would think  that a well placed center punch between the sleeve and knuckle, along with the loctite  would keep everything in place. There should be no torsional load on the sleeve once in place unless the tie rod end was to lock up for some reason.
Personally, I believe the red loctite will keep it in place, but belts and suspenders never hurt anybody.
tuna55
tuna55 MegaDork
1/6/18 8:26 p.m.
There ain't no kill like overkill!
pCV0whXoB6ZglTClgowcIqIWej83OLYdmdhojnbLmvEu3OsEdwEov4x6leAotBqK
