THAT is not a sub $1000 Ford project truck!
Thanks for the offer, though! Do you have a tow dolly with it?
As for my slightly-more-than-$1000 GMC project truck...
I put in all of my grease fittings and greased the whole front end and swung the steering back and forth (TIGHT!!) a few times.
I also swapped out the upper damper mounts with awesome 4x4.com pieces that I am seriously impressed with (I now have them front and rear) and installed the new dampers with new bolts on the bottom as well.
Then I played "where do I put the swaybar" for a few hours.
I was aiming for attaching the drop link directly to the control arm with a new 3/8" hole. Here is what that brought me.
This is convenient because it's super easy to drill a hole. But it won't work because it is too high relative to the bumpstop, too close to the edge of the control arm, andwon't allow for a reasonable bushing beneath the control arm.
Back to the gusseted bracket idea
That works. I don't even have to drill the hole in the bracket! I have to weld on the bracket, though. I took no pictures of this, but if I had been able to attach the bar such that the endlink went through the control arm, I would have had to knock out a GM frame rivet and used the same hole for one of the swaybar bushing bracket attachment points Doing it with the gusseted bracket means that I'll be drilling two new holes in the frame, one slightly forward of said rivet.
No big deal.
I'll drill these, mount the brackets, weld the brackets on and mount the bar totally next time.
