1 ... 18 19 20 21 22 ... 36
OjaiM5
OjaiM5 New Reader
5/12/19 9:47 a.m.
I probably would spring for a gallon of polyester primer, well under $100. High build, will just burry imperfections and is easy to sand.
Just my 2 cents. Can't wait to see this all finished up
maschinenbau
maschinenbau GRM+ Memberand Dork
5/13/19 9:12 a.m.
2nd coat of color #1 is on. I tried one of those disposable hopper cups, but the filter didnt' seal right and I got a ton of clogging on one panel. So I'll need to wetsand before the final coat.
Also...soon...
AWSX1686
AWSX1686 GRM+ Memberand SuperDork
5/13/19 10:53 a.m.
Yes!
What did you cut that with?
maschinenbau
5/13/19 12:06 p.m.
Friend at work has a vinyl cutter, not sure what type, but it's just a little 12x12 hobby one.
maschinenbau
5/13/19 6:05 p.m.
It's hard to show progress when spraing white over nearly-white primer, but here it is anyway.
NOHOME
NOHOME UltimaDork
5/13/19 7:36 p.m.
Awesome!
Dusterbd13-michael
Dusterbd13-michael MegaDork
5/14/19 5:39 a.m.
Im so jealous. Youre already at body work.
maschinenbau
5/14/19 7:39 p.m.
Bottom half done
One or two more colors left...
Indy-Guy
Indy-Guy UberDork
5/14/19 8:18 p.m.
Wholey berkeley! That's looking AWESOME! The Datsaniti sticker nail's it
ShawneeCreek
ShawneeCreek GRM+ Memberand Reader
5/15/19 10:27 a.m.
Looking forward to the final result...
bOttOmfeeder
bOttOmfeeder New Reader
5/15/19 11:03 a.m.
Needs one of these.....Image result for bar code
maschinenbau
5/15/19 7:05 p.m.
Oops. Guess it needs more time to cure so I'll wait a few more days before the final tape job and the final color.
And speaking of color...
wvumtnbkr
wvumtnbkr GRM+ Memberand UberDork
5/15/19 8:16 p.m.
M oar.  Now!
Dusterbd13-michael
5/15/19 8:18 p.m.
Hate to say it, but that looks like an adhesion problem, not a cure problem from my seat. Hopefully I'm wrong.
But im seriously digging it! Martini livery?
STM317
STM317 UltraDork
5/16/19 5:48 a.m.
The masked fender stripes and placement of the "Datsaniti" stickers shout BRE to me
Image result for bre livery
The metallic blue is going to look great!
maschinenbau
5/16/19 6:32 a.m.
Rustoleum paint to Rustoleum primer, but it happens I guess. Or I pulled the tape up from the wrong angle. This was also a trouble spot I had to sand and respray a couple times due to clogs. Isn't learning fun.
STM317 you might be on to something
TVR Scott
TVR Scott GRM+ Memberand HalfDork
5/16/19 6:52 a.m.
Super cool!
I'm really enjoying watching you progress on this one!
Dusterbd13-michael
5/16/19 7:19 a.m.
In reply to maschinenbau :
Been there and done all those. I promise it gets easier the more you do.
maschinenbau
5/16/19 7:47 a.m.
I think it might be the re-coat from the clog fix. I basically wiped the clog spots with a thinner-soaked rag right after they happened, which left a bad smudgy texture. Then after it dried, I wetsanded 1000. Then sprayed real heavy instead of two thin coat because I wanted to be done. I probably should have sanded like 400 or 600 and split into two coats.
maschinenbau
5/17/19 7:19 a.m.
I have no idea what I'm doing. I didn't spray more than a few swipes without adjusting the gun. Sometimes to "splattery", sometimes too thin, sometimes too heavy overlap, it's all over the place. But this one part looks pretty decent.
Dusterbd13-michael
5/17/19 7:20 a.m.
That oughta wet sand and buff out just fine
maschinenbau
5/17/19 7:22 a.m.
Was planning to clear coat over all of it. I'm getting conflicting info on doing anything between base and clear. The can says not to buff for like 30 days or something crazy.
Also, can these instructions possibly be right? I'm using the Harbor Freight "professional" HVLP gun 1.4mm and had it at like 40 psi, but the paint was so thick it barely wanted to flow out. I was having issues getting a full wet pattern, so this coat was pretty dusty in some spots and I sprayed too close to the panels to compensate. Also getting large "droplets" coming out of the gun but often witout a fully covered pattern. Will it flow better at lower PSI? None of this makes sense to me but at least no major defects so far.
wheelsmithy
5/17/19 7:23 a.m.
Dusterbd13-michael
5/17/19 7:31 a.m.
Almost sounds like a thinning or mixing issue. And my gun from Harbor Freight is the $9 special and I generally spray at 50 psi at the hose and reduced down to whatever with the knobs on the gun
maschinenbau
5/17/19 7:34 a.m.
It does feel pretty darn thick, but it came as a kit with 8:2:1 paint reducer hardener. Maybe I'll up the reducer next time. It's WAY thicker than the 1:1 Rustoleum which sprayed way better, but I'm nervous to deviate.
KNOsOYPahdndqP56YWI06LJCOGc6yNyhweuVbyov77txvzSGDGqFSTxa3ENGPxjW
