1 ... 20 21 22 23 24 ... 31
3/11/21 7:29 p.m.
In reply to 759NRNG (Forum Partidario) :
Yessir. And i need to look in the Haynes manual i forgot i have. See if its got anything there for me.
Thanks for the help so far!
3/11/21 7:31 p.m.
test cap came in. We'll see if it clears before worrying about making it look right
3/11/21 9:02 p.m.
Budget first:
previously: 4027.96
new money:
another, correct flexplate: 40, advance
exhaust clamps, amazon: 37.50
driveshaft rebuild and mods: 125
rear main seal: 24.99
billet wheels: 250
fluids, crimp connectors, locktite, etc were generally on the shelf.
Cooper discoverer HT tires in 245/75/16, pretty new: 100
total to date: 4605.45
the last couple of weeks have been pretty nuts, between work and trying to thrash this thing together.
However, ill do my best to cover the work we did. I may miss something, or a lot of somethings. So please, don't consider this comprehensive by any means.
Anyway, we took it down to dads, and disassembled. Drained the fluid, took the driveshafts to the shop for modification, removed the cooler lines, exhaust, manifolds, etc. this thing has been apart before. They RTV'd the converter cover on, missed half the bolts, etc. the cat was also gutted at some point, and the muffler replaced with a two inch in/out piece. Not a lot of pictures, so take my word for it.
20210222_200425 by Michael Crawford, on Flickr
20210223_201226 by Michael Crawford, on Flickr
when we went to drop the actual trans, we learned that the truck is shaped exactly wrong for our lift and shop arrangement. The back of the cab lined up EXACTLY with the garage door opener, and we couldn't go up the whole way. Which meant that we couldn't get the trans jack and trans under and out of the truck. So, doing the trans swap on the lift resulted in me pulling it with a floor jack on my back after having dad lower the lift down once I was underneath. Not fun. But, we did it. Left the converter bolted to the flexplate when we did it to reduce weight id have to handle.
20210223_201232 by Michael Crawford, on Flickr
got the converter and flexplate pulled, found a leaking rear main. Replaced the leaking rear main. My those have gotten expensive from the FLAPS.
20210224_190256 by Michael Crawford, on Flickr
20210225_181059 by Michael Crawford, on Flickr
went ahead and cleaned up the vortec oil cooler adapter, resealed all the threads, etc, really went the whole way on it in hopes of a long, leak free life. I even did it twice! Improper install first time, used the dorman kit from the FLAPS the second time, following some guidance I got online. Success! I also got the new hoses in, the hole in the motor mount for the line clips, cleaned the cooler out in the radiator, etc. you can also see the new trans cooler lines fo rthe 4l80. Well, one new line, one cleaned parts truck line.
20210225_181046 by Michael Crawford, on Flickr
20210228_171049 by Michael Crawford, on Flickr
about this time we put the new trans in. we figured out that the two of us could move it from the tailgate to the rolling cart, roll the trans on the cart under the truck, get the trans jack under the truck, then manhandle the trans onto the jack from the cart under the truck that we couldn't fully stand up under. Yes, it was as sketchy and painful and difficult as it sounds. But that motherberkeleyer went in!!!
20210226_185254 by Michael Crawford, on Flickr
went ahead and got the long tubes in next. The drivers side fell in, passengers put up a bit of a fight but finally went in with brute force and leverage. Got the copper gaskets in, and the insulation on the plug wires. Getting all the header bolts in was definitely tough, especially with carpal tunnel. But after a few hours of aggravation, we got them all in and tight. After a few heat cycles, I put the locks on the bolts. Needed to tweak a couple, and there were two bolts that COULD NOT get locks due to tube proximity. But, done.
20210226_204057 by Michael Crawford, on Flickr
20210226_205513 by Michael Crawford, on Flickr20210228_151811 by Michael Crawford, on Flickr
20210308_181210 by Michael Crawford, on Flickr
the exhaust came next. Unfortunately, the y pipe met with the crossmember pretty hard. Solution was to cut the pipes, shorten a few inches, and clamp back together with the stainless band clamps. Worked out just fine. Sounds good as well! Seems like we make more power with the headers, but too many variables have changed for me to know for sure.
20210228_171008 by Michael Crawford, on Flickr
20210304_190307 by Michael Crawford, on Flickr
im a little out of chronological order here. Sorry. Just too much going on at one time here to really do things justice. Sorry....
anyway, I resealed the trans. New o rings on the sensors, new output shaft seal, filter, trans pan gasket, etc. swapped out the wiring that needed changed and altered, extended the oxygen sensor leads to reach the new location. No sludge in the pan, and it seemed like a great trans. No concerns noted. Went ahead and pulled the grille and front bumper to hook up the auxiliary cooler, as well as the in radiator cooler. And I finally installed the sensor for the outside temp in the overhead console. I was there after all....
the behind bumper air guide was different to clear the cooler lines, FYI. Also the 2500 crossmember was significantly different fron the 1500, so I reused the 1500 piece. I also added the temp sensor in the test port on the trans, and reused the range switch from the 4l60 as I knew it worked.
20210228_170959 by Michael Crawford, on Flickr
20210301_183146 by Michael Crawford, on Flickr
while I was in there, I went ahead and converted to the later AC system parts, except for the compressor and brackets. Just haven't gotten there yet. But its on the short list, cause im fat, live in the south, and drive a black truck....
anyway, getting stuff buttoned up, I noticed that the intake tube to the fender has a restriction at the end. My bet is for NVH reasons, and I could see it choking off power. So I cut it off.
20210228_171109 by Michael Crawford, on Flickr
20210308_181240 by Michael Crawford, on Flickr
20210308_181336 by Michael Crawford, on Flickr
some point in here, I trimmed up the new floor mats. Not mission critical, but felt good to do.
20210228_172008 by Michael Crawford, on Flickr
anyway, today the replacement chip burner came in. the one I had died of old age. Got the new prom burned, put in, and proceeded to do this:
20210311_164521 by Michael Crawford, on Flickr
20210311_164518 by Michael Crawford, on Flickr
runs good, shifts FANTASTIC. Seems slower on takeoff, but thats probably due to the different gearing in the trans.
To finish out this update: I love billet wheels. Im a 90s kid, sue me.
Id been hunting a set for this truck, and came across a fair deal on some eagle alloy 206 wheels, 16x8, wrong center caps, dead tires, and scruffy. $250, which was CHEAP in my area. So I bought them.
Screenshot_20210226-104309_Messages by Michael Crawford, on Flickr
20210226_144536 by Michael Crawford, on Flickr
spent some time with some 1500, 2000, 3000, 4000, and various compounds, and got here.
20210306_141211 by Michael Crawford, on Flickr
mounted up, found the caps didn't even come close to fitting, and started hunting another set. Not about to spend 75 each on ebay, so I went trolling factory caps that may work. Came across these from impala ss. Well see....
20210306_170736 by Michael Crawford, on Flickr
20210311_182609 by Michael Crawford, on Flickr
negotiated a deal for the tires off the service body, which are cooper discoverer Hts, in 245/75/16. should fill out nicely on here with the mudflaps and such.
Stay tuned, more to come later.
Stampie (FS)
3/11/21 9:30 p.m.
That's a good DB13 all the E36 M3 hit the fan but we got it done post.
3/12/21 5:38 a.m.
In reply to Stampie (FS) :
Thanks! I think.
I like summary posts. Gives a big picture,  broad overview to the jobs completed, vs the blow by blow that seems to hyperfocus on bits and pieces taken out of context.
At least to me....
Justjim75
Justjim75 SuperDork
3/12/21 10:11 a.m.
What's a DB13?
Stampie (FS)
3/12/21 10:44 a.m.
In reply to Justjim75 :
Shorthand for Dusterbd13.  I was feeling lazy in my typing last night.
eastsideTim
eastsideTim PowerDork
3/12/21 1:41 p.m.
Amusingly, a set of the same design Eagle wheels in 15x8 with a dual bolt pattern turned up on my local FB marketplace.  Trying to decide if I want to go with a set for for S10.
3/12/21 1:50 p.m.
Do it!!!!
759NRNG (Forum Partidario) UberDork
3/12/21 3:06 p.m.
I know .....I know what I said before, but...........these actually look quite good ........just not my style. Carry on bro ......hey, what car are you and peanut sportin' today????
3/12/21 3:28 p.m.
Today is duster. Tomorrow? Who knows?
Justjim75
Justjim75 SuperDork
3/13/21 8:53 a.m.
Thanks
3/13/21 9:29 a.m.
Figured out the starter issue.
I put the motherberkeleying FLEXPLATE in backwards.
berkeley it. Im done.
Stampie (FS)
3/13/21 10:21 a.m.
I've done worse plus now you have experience so it'll be so much easier.  Not helping is it?
3/13/21 10:34 a.m.
Stamps, you drive right up there right now, and help MCDb13B with your busted knuckle sacrifice...do it!!!!!
3/13/21 11:29 a.m.
I'm walking away for a week or two. The rest of the whole swamp Works flawlessly. I just went and put 50 miles on it. I am going to relax for a little bit and get my peace and serenity back at this particular vehicle, and then Dad brother Dustin and I will bang it out in the Saturday. Should actually be far simpler this time since I don't have to modify anything or add anything or...
Stampie (FS)
3/13/21 12:17 p.m.
I'm always willing.  Just have to make sure I'm back in Jax by 0730 for work tomorrow.
3/13/21 4:49 p.m.
I know you would and I likewise, iffen I didn't live a bazillion miles away from y'all ....late
3/18/21 7:23 a.m.
Saturday, brother Dustin, dad and i hit it. Figure three of us should have it knocked out by lunch.
While its been raining all week, and i couldn't work on the woods or go walking,  ive been polishing. Redid the two id done before,  and am now happy with the results. These are what i had in mind.
3/18/21 8:59 a.m.
And you worked on those AFTER flipping the dang flex plate right????
3/18/21 9:13 a.m.
Nope. Flexplate is this Saturday. Had to walk away for a minute. Do something different. I like polishing stuff. Its fun, so it was a good change. I also cleaned up the vortec accessories so i can get the ac installed, and started cleaning up the electric fans for then as well.
pres589 (djronnebaum)
3/18/21 9:22 a.m.
Smart to find something else to do for a bit with a plan on how to attack it when you have folks helping.  Should make it more enjoyable and a lot faster to get through.
solfly
solfly Dork
3/18/21 10:35 a.m.
good progress man, should ba a nice, well sorted truck before long
3/20/21 11:05 a.m.
Trans out, flexplate flipped,  two bolts in the bellhousing....
3/20/21 2:47 p.m.
Done and almost home!!
PCuNyMVcZpsitDjWAC0NhoYBKpurxoHrac9pqkTh3cN9T9VlaajztwZkODX1xYfW
