Progress Tonight: In order to access the cooling temp sensor, remove the top of the airbox and the bracket that attached the top of the intake and the block.. of the This bracket also holds a small electrical box in place. Removing it helps get a better angle with your socket wrench. I also removed a hose that circulated overflow oil from the top of the head, this hose adn the connector it links to will drip a little oil when you pull it off. Remember, I'm replacing the sensor that sends the temp to the gauge cluster. This sensor is aft, or anterior to the sensor the sends the temp to the ECU. I removed of the wires and labeled one of them for better access.
The 19mm deep socket I purchased was too deep for the tight access and my shorter socket couldn't clear the senor and still reach the threads. There wasn't enough space for my wrenches...other offset or ratcheting wrenches would probably work. I actually just broke the plastic top of the senor off and used the socket to loosen the plug. Upon inspection, it looked like someone had glued the top plastic half of the sensor back into the metal base. Maybe because they couldn't get it out? Either way, I hand-tightened the new sensor in and used an open-ended wrench to get it a little tighter. Surprisingly, the OEM sensor from BMW didn't include a crush-washer...while every aftermarket one I saw did. I know it's probably not a good idea to reuse these, but it didn't look stretched or crushed and I know I could probably take it out in about 15-minutes now that I know how to get access.
Top tip: Once you remove the sensor, coolant will start to flow out of the hole. Put the new sensor in quickly so you don't make too much of a mess. Also, be careful not to drop the crush-washer in your panic/rush to get the sensor back in...that'll result in a bigger mess to clean up.
Key Question: Since I've opened the cooling system, do I need to go through the coolant bleed process?
One more top-tip: There are small clips on the wire plug that connects to each censor. IF you pull them halfway off with pliars, they'll remain in place. If you pry them all the way off with a screwdriver, they'll fall off and likely land in a difficult place to reach. I managed to reach the one I dropped. Eventually.
Here's a picture, in case anyone is ever searching for the plug in an M42. I've unclipped the wire from the sensor.
I started the car up and let it run for about 5 minutes. I also backed it up a few feet to clean up the coolant i leaked on the floor. The temp gauge was working, so that's great. The idle was unwavering and I love the mechanical sound.
Seeing the christmas tree of SI lights reminded me that I still have my SI Reset tool! I knew there was a reason I kept it. I'll have to take a closer look at the brake pads. Even after replacing the pads, rotors and sensors in my old car I could never get that light to turn off. I eventually pulled the bulb when my car needed to pass emissions. Bonus! The car came with a full tank of gas. This also reminds me that the car supposedly has a performance chip...so I guess premium gas is required.
I'll be the first to say I'm not a fan of the faux-carbon fiber cluster. I will say that the chrome rings around the gauges do look good (as long as I'm not blinded when the sun hits the chrome). Maybe I'll vinyl over the carbon at some point? I'll deal with that if/when I decide to attack the odometer gears. I wonder if there's a VIN on the gauge cluster, or some other way to know if it's original to the car.
Another to-do item is the bumper undertray. The plastic skid plate and the brake duct tubes are missing.
