Long time, no updates!
So I bought this car knowing it consumed oil, but from what the PO told me, it was in line with normal consumption for a car this old. I've only put some 2,000 miles on the car since I bought it, but consumption has been all over the place. Around the last race of the season it appeared to go through a quart in 100 miles! This obviously worried me a great deal, as I'm not in a position to rebuild my motor nor buy a new used motor. The PO said he had installed a new CCV in an attempt to manage the consumption, so I figured if that had already been done, the two possibilities are either bad rings or valve seals.
In doing some research on the CCV, I came across a review on Amazon for the knockoff version which said it failed after three months. The knockoff was $30, OEM was $90. What if the PO had installed a non-OEM part and it had failed, leading to my consumption problems? I attempted to diagnose it by removing the oil cap and checking for abnormal vacuum. The car stumbled a bit, but it didn't feel like it was trying to suck my hand into the motor, so I was left unsure of how to assess the results. I figured that putting a new CCV on the car was relatively cheap, so I bought all brand new OEM parts and waited a few weeks until I had some free time to get in there and replace it all.
This weekend, that day finally came. I don't know if the job was made more difficult because of the M50 manifold, but it was NOT a pleasant job. I finally got the old one out and was rewarded for my patience:
It was indeed NOT an OEM piece. Maybe this was the culprit after all!
I also replaced the drain hose back to the pan. The RealOEM diagram showed it with hose clamps on either end, but there were none on my car. Probably not a big deal, since I don't think that hose sees any vacuum, and there were no oil leaks around the ends, but still, proper is proper.
The old one had definitely seen better days.
Even though mine was i good shape, I got a new plastic tube just in case.
Turns out the one on my car was probably not OEM, as the ends of it rotated, while my new OEM one did not. I wondered if allowing the ends to rotate could cause a vacuum leak....
While I was down there, I had to unhook the hose going to this EVAP thingy. It too was looking tired, so I cut 1" off the end and plugged it back in.
After double checking all my connections, I put it all back together and hoped for the best.
Next up, something actually kinda cool. A new/used steering wheel! I have wanting to replace the admittedly pretty nice 3 spoke wheel that came with the car, but money has been tight, so I didn't want to order one without having sold the stock one first. Well, after weeks of it being up for sale, someone bought it, so it was time to remove it and install the aftermarket wheel!
I used this thread as my guide:
http://www.bimmerforums.com/forum/showthread.php?2133134-The-most-in-depth-Z3-Sparco-Steering-Wheel-Install
With my airbag system disabled, I was free to ignore the instructions on wiring in resistors. The only thing to do was to wire up the carbon pin so the horn would work. Well, my car had different wiring that the Z3 in the write up, which for once actually made things much easier. The carbon pin was able to just plug right in to the existing connector, no splicing needed!
And with that, my Sparco wheel was installed with a functioning horn, and so far, working turn signal cancelling. I've had this wheel for years now, and I like it so much that I bought the new version, the L505, for my other car. The M3 (dirt car) gets this old one, and boy does it feel great in my hands. I've used a lot of steering wheels and this one remains my favorite. I don't love the alcantara on the top section, but the grips are just so perfect I can ignore that small detail.
More to come!
