1 ... 10 11 12 13 14 ... 16
759NRNG
759NRNG PowerDork
6/13/23 9:16 p.m.
carry on cap'n chaos....
759NRNG
759NRNG PowerDork
6/13/23 9:20 p.m.
Do those upper links pose some head scratchin' when it come time to route the exhaust?
Patrick
6/14/23 2:17 p.m.
I'll burn that bridge when i get to it
made brackets for each side to put the upper shock bolts in double shear for my peace of mind
Patrick
6/15/23 10:53 a.m.
have excellent range of motion with no binding anywhere. Can let one side droop and pick the other up to hit the bump stop very easily.
assembled the rebuilt locker from Pete into the 3.25 center section from Gimp. Got all but one of the studs for that pulled in, ripped the threads off that one and have to cut it off because the nut is stuck on it. Thankfully the pack came with 2 extras because another one snapped, not thrilled with the quality but they're functional.
Patrick
6/15/23 8:11 p.m.
Pumpkin installed, axles cut to length and installed. Found my wheel studs and all the brake parts, waiting on hardware to come tomorrow to finish the shock install and get it off the rims/wood
spinning the yoke and watching both axles spin the same way. It's a good thing
currently hunting a driveshaft and having the debate of have the local dude make one or just order one from speedway that will show up ready to slip in
Patrick
6/17/23 8:38 p.m.
It rolls again
have to adjust upper arms to set pinion angle and tighten all the fasteners.
759NRNG
759NRNG PowerDork
6/17/23 10:05 p.m.
Wow!!! In two days speedway hooked you up with the Dshaft of Yo dreamz....simply Amazing!!!!! ....or am I over reacting on your progress?????
Patrick
6/18/23 7:46 a.m.
In reply to 759NRNG :
Nope. In one day I did the research and found an astro van 2wd shaft is what I need and got one for $35 at the junkyard, already pulled and tagged and brought out to my truck. Ive got to clean and paint it and install a conversion joint on the rear but otherwise correct length, correct yoke, etc. counting the new joint, saved my tight budget $350.
however, speedway had the Wartburg driveshaft here the next day. They don't jack around with shipping lag
preach (dudeist priest)
preach (dudeist priest) GRM+ Memberand SuperDork
6/18/23 3:52 p.m.
Saw your IG post, man I'd E36 M3 if that thing pulled up next to me. So cool, Patrick.
Patrick
6/18/23 8:37 p.m.
I could not leave things alone until next week so I set the pinion angle and centered the axle under the car by adjusting the top links.
Norma66-Brent
Norma66-Brent HalfDork
6/24/23 8:45 p.m.
Excited to see ride height and stance soon!
Patrick
6/29/23 8:13 p.m.
Unhappy with the stockish width rear axle, I made it 4" narrower
Mucho gusto
Swapped over to a 4" backspace wheel instead of the 5" that was planting the tire firmly into the body before
This makes me happy
11GTCS
11GTCS Dork
6/29/23 9:51 p.m.
In reply to Patrick :
I’ll be in my bunk? laugh  Damn son.
759NRNG
759NRNG PowerDork
6/29/23 9:54 p.m.
Yo P I get the lathe two step at the hub.......but how do you square the cut on the Diff?
dyintorace
dyintorace GRM+ Memberand PowerDork
6/30/23 6:45 a.m.
Man! That wheel/tire setup looks amazing!!
Patrick
6/30/23 8:22 a.m.
Duct tape wrap and angle grinder. I have a jig that lines everything up so 95% is close enough
maschinenbau
maschinenbau GRM+ Memberand UberDork
6/30/23 8:43 a.m.
Nice fitment! I did not see that wheel and tire coming...I like it
Patrick
6/30/23 12:55 p.m.
In reply to maschinenbau :
been itching to do something with meaty 15" again. Bought these wheels for my 54 Belair like 10? years ago and they've been boxed in the basement collecting dust and mouse crap. Much like the car has been sitting in my dad's barn doing the same as I got distracted with kids and like 50 other cars. trying hard to fight the adhd.
759NRNG
759NRNG PowerDork
6/30/23 7:17 p.m.
weld porn please.......is Warren's Toyota hiding in the driveway ?
Patrick
6/30/23 7:36 p.m.
Nope we'll pick that up in august or September
Norma66-Brent
7/1/23 11:39 a.m.
The wheels are perfect man.
wawazat
wawazat SuperDork
7/1/23 12:19 p.m.
Agreed.  Wheels look good!  What are your plans for the fronts?
Patrick
7/1/23 6:22 p.m.
In reply to wawazat :
Same or a 15x7 not sure yet. Hoping the 15x8 with 5" backspace is a good fit up front because I have them. Based on how 15x8 with 4" backspace sat, they should be perfect as long as there's not too much inside the hub to cause rubbing anywhere
Patrick
7/1/23 7:32 p.m.
Remember that time I stimulus checked a tanks inc coated gas tank with in-tank 255lph pump and sending unit to work with the stock fuel gauge? Neither does Carli. However, I'm a couple wires away from slapping it in.
Patrick
7/7/23 8:35 p.m.
UbvXfLK3WoQhnDPUZUpie4cuVBQbXitJS0G772WxO6LrfE6GXD91hX1UyDV1MKHw
