1 ... 84 85 86 87 88 ... 99
ShawneeCreek
ShawneeCreek GRM+ Memberand HalfDork
9/7/21 11:23 a.m.
Dusterbd13-michael said:
centers: cast coat iron or cast coat aluminum engine paint? Or something im not thinking of?
Call me crazy, but a bright yellow or gold could be fun.
TVR Scott
TVR Scott GRM+ Memberand SuperDork
9/7/21 12:11 p.m.
Yeah, I thought the yellow was intentional.  And I think it looks pretty cool.
Dusterbd13-michael
Dusterbd13-michael MegaDork
9/7/21 1:34 p.m.
Well....
I went cast coat iron....
i got two painted between pre-work and lunch. Two to go.
Then 245s and a test fit!
Dusterbd13-michael
9/9/21 6:18 a.m.
Im anxious to see if they fit. Its a lot of tire.
Justjim75
Justjim75 SuperDork
9/9/21 8:36 a.m.
That setup will be soo berkeleying sexy
Stampie
9/9/21 10:25 a.m.
Are they on yet?  We're waiting.
Dusterbd13-michael
9/9/21 10:38 a.m.
In reply to Stampie :
Soon....
Like after work, assuming that i get the oiling system finished up and it doesn't leak. Or explode.
Pics as soon as i do. Promise.
Stampie
9/9/21 10:41 a.m.
Like after you call out from work or after you do a full day of work?
Dusterbd13-michael
9/9/21 10:45 a.m.
Full day....
No time off from new job. Yet.
maschinenbau
maschinenbau GRM+ Memberand UltraDork
9/9/21 10:51 a.m.
I don't remember - is this coming back to the Challenge this year or have you blown the budget by now?
AWSX1686 (Forum Supporter)
AWSX1686 (Forum Supporter) GRM+ Memberand UltraDork
9/9/21 10:52 a.m.
New job? Hopefully that's going well for you. I seem the recall the old job taking quite a toll.
Dusterbd13-michael
9/9/21 10:54 a.m.
In reply to maschinenbau :
Absolutely blown the budget.
Still the same basic car, however. The oiling, aero, and suspension tweaks put it over though
Dusterbd13-michael
9/9/21 11:40 a.m.
In reply to AWSX1686 (Forum Supporter) :
So far! Only week two though. And im doing the same thing for one of the companies that inherited my old territory. But, its employment!
9/9/21 2:13 p.m.
Well, I hope it continues to go well for you!
Dusterbd13-michael
9/9/21 6:12 p.m.
Dusterbd13-michael
9/9/21 6:19 p.m.
Stampie
9/9/21 6:23 p.m.
Box flares?
sleepyhead the buffalo
9/9/21 6:27 p.m.
so, I know a guy who's been running 245's...
I should look at the XB rules again, w.r.t. aero.
also, 245's... means you probably want to think hard about getting the "pricey" up-rated race hubs.
Dusterbd13-michael
9/9/21 6:41 p.m.
In reply to sleepyhead the buffalo :
Im going to need more information and a build thread....
9/9/21 7:42 p.m.
no build thread.  it's a GridLife GLTC build, so that means it's K-Swapped.  I've been giving them some remote aero advice while I was away; so I know fair amount of the build.
The 'front end' is basically a bumper chop with HDPE(?) riveted to the bumper at the top, and screw/bolted to reinforcements on the upper side of the wooden 'undertray' (i.e. a splitter that doesn't stick forward of the front bumper... which in GLTC rules means no lb/hp penalty).  It's a concept that got explored in CFD about a 6 or 7 years ago:
Splitter or Air Dam – Which Design is Best? | Hancha Blog (wordpress.com)
Air Dam or Splitter - A Closer Look | Verus Engineering (verus-engineering.com)
Also, there's an aluminum duct from the cutout in the black plastic to around the radiator (opening is ~1/3 the size of the radiator face).  There's some in-work ideas about improving the exit from the radiator out the hood (I think I've alluded to being disatisfied with the vents on that car in other posts).
I think the front fenders are just rolled/pulled.  The bumper has a push-button lock a the upper corner that's spaced out from the body.
on the backside of the fender... it's a bit complicated to explain.  But there was a simplified version that was tried just by spacing the bottom of the rear of the front fender out... 4? inches with a bit of aluminum.  However far out it took to make the fender match up with the outside of the tire better.
On the back, I'd probably suggest you stick with your spoiler for now.  And I'd suggest your keep your rear bumper on.
Loweguy5 (Forum Supporter)
Loweguy5 (Forum Supporter) GRM+ Memberand Reader
9/9/21 9:22 p.m.
As one who has spent little time on the forum lately, I can only say that this looks nothing like the blue Neon I was expecting to see.  Further, I'm too tired tonight to set about reading 87 pages of this thread to learn how we got here...
Dusterbd13-michael
9/10/21 4:55 a.m.
In reply to Loweguy5 (Forum Supporter) :
This is a previous challenge car.  Blie neon is blown up at the moment. This is my primary track car.
pres589 (djronnebaum)
9/10/21 8:43 a.m.
Am I weird for thinking that wheel/tire/car package looks cool from here?  I don't know if I'd mess with flairs yet when the combination isn't 100% settled on anyway unless it's a track requirement.
Dusterbd13-michael
9/10/21 9:00 a.m.
Nope. I really dig it too. If it doesn't rub, im going to run it just the way it is!
Dusterbd13-michael
9/10/21 6:54 p.m.
It rubs multiple places at rest while cycling the steering. No way it will clear and be functional. Dammit.
Also, i have a bad fitting causing a good size leak. Had to order another. Unfortunately it is the single hardest fitting to get to. Dammit...
At least i still have one more weekend before tbe event, right?
AY51W2xNta5mxQFnQPdwtiXQoVtvTYYGkplAlojOo9rIt3HJjgYiXIshH7wqi4B5
